Need Help Purchasing New 3D TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-23-2012, 11:31 PM - Thread Starter
fkerner's Avatar
I've been lurking the forums for a while now,as well as doing more research for this than my schoolwork, and finally it's the time to purchase a 3D television set. I just need help figuring out a good one!
What I want:
Passive 3D
LED Screen
2D to 3D Conversion
55" or greater
$1400 or less
I've had my eye on the Toshiba 55TL515U and the LG 55LW5600, but I keep hearing negatives on both regarding lighting issues etc.
Note: I'd be using the television for watching TV shows (3D and regular,) movies (3D and regular,) and gaming (3D and regular.)
And that's about it. What Television sets would you suggest? Thank you all very much! I'm so confused right now.
fkerner is offline
post #2 of 13 Old 02-24-2012, 07:06 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
Hi fkerner, I for one don't own a 3d tv as of yet but I'm planning on it. But I definetly know that it has to be passive 3d. I find it is so much easier on my eyes and looks better. Out of the two I would go for the LG 55LW5600. Toshiba just doesn't stack up these days. I personally am waiting for how much the new LG Oled 55" is going to cost. If it cost way too much, I 'm probably going to get the new LG 55" LED LM9600 coming out soon. It is a stunning looking hdtv. Good luck on your decision.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 13 Old 02-27-2012, 10:59 PM - Thread Starter
fkerner's Avatar
Thank you latino,
I heard that the LGs have horrible gaming lag, which is a huge drawback for me. Is this the case?
Would anyone else recommend any other TVs? I'm unsure of Active 3D and I've heard the glasses can cause problems and are a bit bulky, but I'm open to suggestions.
I'd still like an LED-LCD HDTV with at least 1080p, little to no gaming lag, and 2D-3D conversion. Thanks again!
fkerner is offline
post #4 of 13 Old 03-04-2012, 05:35 PM
systox's Avatar
hey, i know the other guy recommended against toshibas but i hear they're the only ones that have their head in the game when it comes to gaming on a passive set. I read alot about how the tl515u toshiba has very low lag while the lg's have very high lag.
This is from research that i have done online so if someone with first hand knowledge of BOTH sets says otherwise, you should take their advice.
systox is offline
post #5 of 13 Old 03-04-2012, 06:19 PM
buonforte's Avatar
Originally Posted by Latinoheat View Post
Toshiba just doesn't stack up these days. .
Really?? I first had the LG6500 and returned it for the Toshiba. Best move I ever made, The Toshiba blows the LG away.
The LG has the worse tuner I've ever seen in my life. Now remember, first and foremost it's a TV. And a TV's primary job is to bring in TV stations. Now if you have cable or satallite, that's no problem but if you don't and are relying on the TV's tuner to pull in your HD channels, DO NOT look at the LG. The tuner in this TV sucks. It only pulled in 3 to 4 channels while with the Toshiba I get around 30, yes 30 OTA HD channels. And that's just one of the many things that make Toshiba better.
buonforte is offline
post #6 of 13 Old 03-04-2012, 08:20 PM
Augerhandle's Avatar
Quoted: 749 Post(s)
Liked: 649
Originally Posted by fkerner View Post
Thank you latino,
Active is just fine, and I have no gaming lag on my DLP. I prefer DLP for no ghosting (much faster pixel response than LCD or plasma), and a size that is perfect for 3D. They also have 2D to 3D conversion.
Size is the number one feature for 3D and one can get DLPs in sizes from 73"-92" with street prices around $1300-$4000, but I've seen 73" for under $1000 on sale, and under $700 on Black Friday. Dell has them on sale sometimes, starting under $1000 depending on model and features.
And I love this ad, it says it all.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #7 of 13 Old 03-04-2012, 11:56 PM
systox's Avatar
in my opinion the dlps are best especially because they work great with 3dvision from nvidia. However you have to remember they are bigger and heavier than your flat screen solutions and may require a bit more maintenance. Still the trade off if you have the room for it is worth it.
systox is offline
post #8 of 13 Old 03-05-2012, 02:00 AM
Quoted: 749 Post(s)
Liked: 649
Check your facts.
My 65" DLP weighs less than 75 lb., and a 65" LCD (LG Infinia 65LW6500) weighs over 100 lb, Even a 73" DLP weighs less than that at around 90 lb.
http://www.amazon.com/Mitsubishi-WD-.../dp/B004ZL2OOU
http://www.amazon.com/LG-Infinia-65L.../dp/B004OVEVOC
post #9 of 13 Old 03-05-2012, 07:58 PM
systox's Avatar
thats crazy my 3d plasma and led weight around 45 pounds each
systox is offline
post #10 of 13 Old 03-05-2012, 09:00 PM
Quoted: 749 Post(s)
Liked: 649
I provided links, so don't take my word for it. What size/model TVs do you have?
post #11 of 13 Old 03-05-2012, 11:19 PM
systox's Avatar
@auger I was commenting on the weight of those sets not the accuracy of your statements.
the two sets i was mentioning are the 42tl515u which comes in at 37.5 pounds and the panasonic 42st30 which ran 51.8 pounds. I also have a 42lh30 from LG which weighs 38.4 pounds. theres another set in the house which measures at 42 inches and weighs under 50 pounds, idk what panasonic model it is though.
anyhow op, if you're still reading through this, don't forget to take into consideration how much room you have wherever you plan on sticking your display. the dlp's stick out in the back about 20 inches. So all in all, if you have a sturdy base, and room for the backend of the TV i DO recommend the dlp's for their great pq in 2d and especially in 3d, don't be thrown off by the active 3d.
That being said, if you're dead set on passive, LED technology, or have limited size/weight constraints i recommend taking a look at the toshiba tl515u. The tv is great for gaming as it has (reportedly) some of the lowest input lag on passive displays of that size. Also, take into consideration that the larger the tv the more it will weigh. For example the 55 inch version of the toshiba which i listed above weighs 55 pounds. Good luck, and I hope you find a solution that works best for you.
p.s. if you are still stuck between the lg and toshiba, i think it comes down to how important gaming is to you. the lg has more input lag but better pq (so i hear). Seeing as how they both suffer from similar lighting issues, i think it would be possible to purchase one on amazon and if the light problems are really as bad as they say, then just tell amazon its defective and return it for a full refund. I'd check to see if any others had luck with that approach first though.
systox is offline
post #12 of 13 Old 03-06-2012, 01:55 PM
Quoted: 749 Post(s)
Liked: 649
anyhow op, if you're still reading through this, don't forget to take into consideration how much room you have wherever you plan on sticking your display. the dlp's stick out in the back about 20 inches. So all in all, if you have a sturdy base, and room for the backend of the TV i DO recommend the dlp's for their great pq in 2d and especially in 3d, don't be thrown off by the active 3d. ...
Well, that's what you get comparing a 42" TV to a 65" or 73" TV. It's like saying Fords weigh more than Chevys, then saying you meant toy Chevys.
As for room behind the set, a 73" DLP is less than 18" thick, and fits on a plasma or LCD TV stand with no problem (my AV receiver is deeper than a DLP).
A flat panel used, as in most homes, on a TV stand requires a base that is also 14"-18" deep just for balance. So, if you're using a TV stand and not re-wiring your room to mount it on the wall, DLP works just as well.
In fact, a DLP looks sleeker than a flat panel TV because the bezel around the screen is only about 5/8" compared to two or three inches on your typical flat panel. You can see the difference in bezels below.
Of course, a smaller flat panel is fine as well, it's up to the buyer. Size is usually the number one prerequisite for a TV though, and with 3D, screen size is everything. I chose DLP for picture quality, size, and price. It was only later that I learned that it was the best for 3D because of its superfast pixel speed and lack of ghosting or crosstalk in 3D, and that is why I recommended it.
post #13 of 13 Old 03-06-2012, 06:26 PM
gosugadget's Avatar
What I want:
Passive 3D
LED Screen
2D to 3D Conversion
55" or greater
$1400 or less
I'm not too sure about the Toshiba but the LG lw5600 is the best bang for the buck TV. Light bleeding may be an issue but it is not with all of the TVs. If your worried about lighting issues, get a LG LW6500, 47 inch. It will cost about 1600 though. If you must stay under 1400 get the LW5600. You wont find a better passive 3D TV.
gosugadget is offline
Reply 3D Displays
