Does anyone know about samsung plasma - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2012, 05:52 PM - Thread Starter
tonyjd40's Avatar
Here is my question. The XXUNES8000 comes with an IR blaster - this is so not only can you control the tv by voice but also the set top box, blu ray player etc... now the XXPNE8000 does not come with the IR blaster, so does that mean the XXPNE8000 does not have that feature , or do you have to buy an IR blaster to use this feature ? I am looking at buying the 64PNE8000, or the 60UNES8000 , or the Panasonic 65VT50, depending on the answer to this question.
THX
tonyjd40
you can dream of where you will be ten years from now,or
you can work hard today to actually get there
tonyjd40 is offline
Old 02-26-2012, 06:14 AM
samsungue46's Avatar
This product made from Korea. But i did not get any news about voice controlling, here is the all deals http://www.televisioninfo.com/conten...And-Remote.htm
samsungue46 is offline
