Blocky 3D Image? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-11-2012, 01:32 PM - Thread Starter
themoneyshot978's Avatar
Hey guys I have the following setup:
Vivitek D538W 3D Projector (http://www.amazon.com/Vivitek-D538W-.../dp/B004IOUVOO)
3D DLP Link Shutter Active Glasses
WD TV Live (http://wdc.com/en/products/products.aspx?id=330)
HDMI Cable (http://www.ebay.com/itm/ULTRA-PREMIU...-/380389564176)
Basically when I try to run mkv 3D files the image is "blocky", for really thin lines or sharp edges the image will be blocky/jagged. I've tried everything from playing with the settings to getting a better HDMI cable with no solution. The videos I ran were 1080p and 720p, with the same problem. The WDTV Live is set to play at 720p 60hz 12bit. Any ideas guys? Thanks!
themoneyshot978 is offline
Reply 3D Displays
