Samsung UN40D6420 Firmware v1028 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-20-2012, 07:34 PM - Thread Starter
Goomohn75's Avatar
If anyone else downloaded the Samsung firmware update v1028 (not v1026) via the TV's upgrade function please let me know. I Had a beautiful vibrant lifelike television until I installed the firmware and now it is dull, washed out and the colors are not sharp with a lot of pink. It looks like an old CRT or computer monitor now. There's even a strange "film" or "layer" of motionless noise or artifacts that sits just above the pictures layer like a mesh of crap. If anyone else is having issues similar to mine please respond. Thank you very much
-|Bryan
Goomohn75 is offline
post #2 of 7 Old 03-22-2012, 09:16 AM
samehereasthere's Avatar
This should probably be moved to the LCD/LED forum for more results but I did notice that the 1028 update is not showing up for me on the Samsung website yet it does show up on my TV update?
Strange.
samehereasthere is offline
post #3 of 7 Old 03-22-2012, 09:22 AM
SolidSignal's Avatar
I've seen that before, where the TV will find firmware before it's published.
To the thread starter's question, I wonder if the TV changed modes by mistake. Go into the Tools menu and see if changing the display mode helps you.
I have the Samsung UN46D6420 and it updated without issue.
SS@SolidSignal
SolidSignal is offline
post #4 of 7 Old 03-24-2012, 08:35 AM
LBJ2's Avatar
-|Bryan
Goomohn75
Check your TV settings. Sometimes firmware updates will reset all your settings to default. You may just need to reapply your previous settings.
LB
LBJ2 is offline
post #5 of 7 Old 03-25-2012, 09:50 PM
Krithren's Avatar
I've got the UN46D6420 and updated it to 1028. No problems with anything post update. A little frustrated that the Smart Hub put a bunch of junk back in there post update, but easy to delete again.
Krithren is offline
post #6 of 7 Old 07-02-2012, 11:00 AM
TonyTone2013's Avatar
Yes I have the same infuriating problem. I have a UN46D6400 that had a wonderful, vibrant picture. After the firmware "update", it looks much worse. It's like looking through a film over the picture. Also now have vertical bands of light and dark across picture. Really not cool. It really shows up when displaying darker scenes. I have a theory - I think it could be some type of copy protection added in the new firmware to keep people from video recording the screen to pirate movies (just a theory at this point.) Have you found a solution?
TonyTone2013 is offline
post #7 of 7 Old 07-27-2012, 10:45 AM
Reply 3D Displays
