What are your thoughts on the Acer HS244HQ?Do u recommend it?24" 1080p 120hz 2ms led - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-24-2012, 03:19 PM - Thread Starter
un55d6000's Avatar
Quickly its a 24" active 3d LED monitor; highlights are 1080p, 120hz, 2ms response, 12m:1 contrast ratio, with hdmi, built in speakers, and comes with active shudder glasses for $300.
its a replacement for a sony playstation display that broke, its going to be used with a ps3 for 3d gaming and blu ray (3d). the sony was gorgeous, but a real cheap defective POS that broke only a week after buying it.
is this acer a good set, will the pq be as good as the sony which had 240hz?
FULL SPECS: http://support.acer.com/acerpanam/MO...244HQsp2.shtml
un55d6000 is offline
post #2 of 3 Old 03-24-2012, 11:11 PM - Thread Starter
un55d6000's Avatar
BEST 3D Display/tv/monitor for the money hands down!!!!!! only thing that had the potential to come close was the sony but they are defective out of the box. i have yet to see something as good at this price point or even close for even under $400. thanks for the help!
post #3 of 3 Old 01-26-2013, 04:30 AM
danalej's Avatar
I received one of these Ibought from ebay...
I was tryin to get it working with my Asus 3dtv play capable laptop and the 3d feature did not work
I also tried using a PS3 with NBA 2K12 wich is a 3d capable game, no luck.
This monitor shows the 3d acer logo when I activate the 3d vision software or the ps3 but the glasses dont do anything.... I can see that the IR emitter turns on, Ive tried two different 3d nvidia glasses.
PS: The glasses I received are 3d vision, but I read that this monitor is not 3d vision compatible...
I'd like to try with the acer glasses it was suppossed to come with:
These: http://store.acer.com/store/acerna/en_US/pd/ThemeID.30483300/productID.258310800
DO you think this is the problem?
Please help.
danalej is offline
Reply 3D Displays
Sony Playstation 3 60 Gb
