3d Blu-Ray Player Not Detecting 3D Display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-25-2012, 01:19 PM - Thread Starter
nytmare11's Avatar
Hello - Having problems with my TV and Blu-ray player being able to talk with each other. I've searched the forum, but haven't been able to locate a solution. I'm trying, for the first time, to watch a 3D movie and am having problems. I have a Mitsubishi WD65835 TV and a Panasonic BDT-310 Blu-ray player. The Blu-ray player says that it can't locate a 3D display (I've turned the 3D on for the TV).
The HDMI ports for the TV lead to: port 1 to my cable box (DirecTV) and port 2 to the blu-ray player's "AVOUT MAIN". The Blu-ray players connected to my receiver via the optical terminal (my HT receiver's a bit old, but works well otherwise).
Any suggestions why the Blu-ray player can't see the TV? Thanks...
nytmare11 is offline
post #2 of 4 Old 03-25-2012, 03:56 PM
PaulGo's Avatar
Quoted: 184 Post(s)
Liked: 105
You have to put the Panasonic player into the checkerboard 3D mode for it to work with this set. The instructions should be in your Panasonic manual.
PaulGo is offline
post #3 of 4 Old 03-25-2012, 03:58 PM
walford's Avatar
I can find no specifications that say that your 5 year old DLP TV is 3D capable. See:
http://reviews.cnet.com/projection-t...g=mncol;subnav
Note: this post was made before I read PaulGo's post above
walford is offline
post #4 of 4 Old 03-25-2012, 05:07 PM
PaulGo's Avatar
Quoted: 184 Post(s)
Liked: 105
It is 3D capable see the Mits site:
http://reviews.mitsubishi-tv.com/517...ws/reviews.htm
http://support.mitsubishi-tv.com/fil..._specsheet.pdf
PaulGo is offline
Reply 3D Displays
