Need help with 55" 3D TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-30-2012, 05:37 PM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
Hi,
For a change wife is in agreement and wants a 3D. I guess out budget will only allow us to go upto 55", so I need to model number and names of brands which I should be looking at in my research. Budget is $1500.
Kindly suggest which ones have the best bang for the buck? Vizio, Samsung, LG
sid369 is offline
post #2 of 6 Old 03-30-2012, 05:38 PM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
oh should I be looking at Plasmas? or I should just stick with LED's
sid369 is offline
post #3 of 6 Old 03-30-2012, 07:35 PM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
There's lots of experience here to tap for recommendations. I've had a Samung 3D plasma, PN58C8000, for a year and a half, and I'm not very happy with the 3D -- I very seldom use it. I do get the 3D effect and there's not too much aliasing, but the picture is rather dim and the colors look unnatural. I don't like it. (2D on the set is fine, though.)
Greg Lee
GregLee is online now
post #4 of 6 Old 03-31-2012, 04:53 AM
Augerhandle's Avatar
Quoted: 746 Post(s)
Liked: 649
Hi,
55"? For about 2/3 of your budget, you can get a 73" Mitsubishi DLP 3DTV.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #5 of 6 Old 03-31-2012, 06:57 AM
ssgmun5000's Avatar
Just saw the 55" LG LM6200 for $1199 on Frys website. It is a lower model in there line but looked pretty good from the demos I have seen at the store.
ssgmun5000 is offline
post #6 of 6 Old 03-31-2012, 06:33 PM
man4mopar's Avatar
When it comes to enjoyable 3D two things are very important. No ghosting/Crosstalk and large size.
In general as for tv tech, tests have shown DLP to be the only tech that is ghost/crosstalk free. The new high end Plasma's by Panasonic are suppose to be near DLP ability. LCD or LED/LCD is the worst of the 3. Due to the fastest pixel change of a LCD is 2ms and Plasma and DLP both are a few thousand time's faster. Sofor the limited budget I agree with Augerhandle and recomend looking into the Mitsubishi DLP's.
No tech is perfect they all have a draw back. Research and decide what draw back least effects you.
man4mopar is offline
Reply 3D Displays
