LG 55" 55LM7600 calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 04-18-2012, 07:33 PM - Thread Starter
cow736's Avatar
Anyone have calibration settings done with a calibration disc, professionally done or done by them self?
Would love to try other settings.
Here's one from another forum member.
http://www.avsforum.com/avs-vb/showt...9#post21795429
Found this from a review site. I guess it's professionally calibrated?
http://reviews.lcdtvbuyingguide.com/...-settings.html
cow736 is offline
post #2 of 20 Old 09-20-2012, 02:18 PM
sjoshi80's Avatar
Hello was wondering if anyone will post their video settings.
Does anyone use TruMotion for sports? When I do, I get an effect where the ball or players will be blurry and tripple.
sjoshi80 is offline
post #3 of 20 Old 09-20-2012, 02:49 PM
sjoshi80's Avatar
sjoshi80 is offline
post #4 of 20 Old 09-24-2012, 07:03 PM
jcbydesign's Avatar
C/Net's calibration/settings for the LG lm7600: http://forums.cnet.com/7723-19410_102-573198/lg-47lm7600-picture-settings/
Haven't got mine yet so let me know how this works.
jcbydesign is offline
post #5 of 20 Old 12-19-2012, 03:39 PM
tikkismith's Avatar
Set mine to there settings and it looks great. Try it.
tikkismith is offline
post #6 of 20 Old 01-01-2013, 07:01 PM
DMBatCOFC's Avatar
Firstly, I want to preface these calibration settings with the following:
I'm a FAN of the "soap opera" effect. I like how clear it is. So, if you don't like this, I wouldn't bother applying these settings. These settings are months worth of fine tuning. I use this in every environment and find it to be the clearest and most color accurate for me. I hope this helps at least ONE PERSON out battling calibration settings for their 55LM7600.
Settings:
Energy Saving: OFF
Picture Mode: isf Expert2
Backlight: 75
Contrast: 80
Brightness: 50
H Sharpness: 50
V Sharpness: 50
Color: 50
Tint: 0
Expert Control:
Dynamic Contrast: Off
Super Resolution: Off
Color Gamut: BT709
Edge Enhancer: High
Color Filter: Off
Gamma: 2.2
White Balance:
Color Temperature: Medium
Method: 20 Point IRE (See Settings Below)
Pattern: Outer
Luminance: 130
IRE Settings:
IRE Value: Red, Green, Blue
100: 12,21,9
95: 50,50,40
90: 50,50,37
85: 42,22,32
80: 34,18,36
75: 40,20,42
70: 50,30,50
65: 50,34,46
60: 29,18,24
55: 24,11,26
50: 22,4,18
45: 24,12,22
40: 20,9,20
35: 18,10,18
30: 15,7,14
25: 4,0,4
20: 2,-1,2
15: 2,2,4
10: 10,8,2
5: -3,4,-16
Color Management System Settings:
Color: Saturation, Tint, Luminance
Yellow: -10,1,-2
Red: -6,5,17
Green: -10,8,4
Blue: 8,0,5
Cyan: 0,5,5
Magenta: 0,-1,4
Picture Option:
Noise Reduction: Off
MPEG Noise Reduction: Off
Black Level: Low
Real Cinema: On
LED Local Dimming: High
TruMotion: User (De-Judder @ 10, De-Blur @ 10)
Aspect Ration: Just Scan
Feedback and results are greatly appreciated.
Flack1 likes this.
DMBatCOFC is offline
post #7 of 20 Old 02-08-2013, 03:14 AM
TCRalph's Avatar
Hey DMBatCOFC I was just wondering how you came by those settings and if your tv was professionally calibrated. But other wise I will give these settings a go on my LM7600.
TCRalph is offline
post #8 of 20 Old 02-13-2013, 07:05 AM
DMBatCOFC's Avatar
Hey TC,
I got to these settings after months of fidgeting! I haven't had the TV calibrated, however, I just hit silver status with Best Buy and will be taking advantage of the free calibration service in a couple of weeks. I will post those results after the TV has been calibrated.
Adam
post #9 of 20 Old 02-13-2013, 08:32 AM
thedataman's Avatar
I used a Combination of DMBat's settings and setting from these 2 sources.
http://reviews.lcdtvbuyingguide.com/lg-lcd-tv/lg-lm7600-calibration-settings.html
I ended up with 2 custom settings using each of the ISF Expert options. I ended up tweaking and switching between the 2 ISF options and ended up going with DMBat's settings for the most part. I took a few settings from the other recommendations over DMBat's but for the most part, with the exception of a handful of changes, I love how the set looks....in SD, HD, and 3D....
After 1 day I could not be happier...I am sure at some point I will end up tuning more...but for now...very pleased.
thedataman is offline
post #10 of 20 Old 02-13-2013, 06:48 PM
DMBatCOFC's Avatar
Thank you very much for the feedback! I'm glad it's working out for you. I like your hybrid solution, as each person's preferences are different.
post #11 of 20 Old 02-16-2013, 01:54 AM
Mattyice21's Avatar
I just purchaseda my new lg 555LM7600 and cannot wait for it to get here... Anyone have any other input or could post up more exact specs on tweaking? What is a soap opera effect mean? Also dataman would you mind posting your settings?
Mattyice21 is offline
post #12 of 20 Old 02-18-2013, 09:36 AM
DMBatCOFC's Avatar
Hey Matty! The soap opera effect means that the picture refresh rate is so high that the picture almost looks fake or 3D - crazy smooth movement. A lot of people don't like it - I do. A down side to this is that sometimes you'll see blooming around fast-moving objects with the TruMotion - a true 240hz refresh rate would/should eliminate the blooming. I just can't afford to drop thousands on a real 240hz set. Hope this helps.
post #13 of 20 Old 02-18-2013, 09:50 PM
Mattyice21's Avatar
Thanks for the explanation!! That's good to know, sorry I'm new to all this tv lingo. This is the first real set I want to dial in close to perfection! Any thoughts and tips would be greatly appreciated. I also purchased the Disney blu ray world of wonder 2 disk set. Anyone here ever use this? What's your take on it?
post #14 of 20 Old 02-25-2013, 09:20 AM
EaglePC's Avatar
It's a WOW With DMBatCOFC settings only thing changed was LED Local Dimming:Medium
TruMotion: User (De-Judder @ 2, De-Blur @ 5) no soap opera effect even with TruMotion on
RF61ii's
RC42ii
WS24's
RW-10D subwoofer
ONKYO AVR TX NR818
Oppo BDP-103
Cyber Power PFC 1500VA UPS
LG 55in 240hz LED 55LM7600 TV
EaglePC is offline
post #15 of 20 Old 02-27-2013, 01:43 PM
DMBatCOFC's Avatar
Thank you for the feedback! I'm going to be applying your de-judder and de-blur settings to my set as soon as my wife gets done watching her TV show. Glad my settings helped you out a bit!
post #16 of 20 Old 05-19-2013, 06:15 PM
haykat's Avatar
HI
I got this set a couple of months ago and really like it.
Wondering how the Best Buy calibration worked out for you and compared to your own?
Is it true that calibrating on ones own, in the expert settings, voids the warranty? I haven't tried your personal calibrated settings yet and am a little worried about somehow screwing it up?
thank-you!
haykat is offline
post #17 of 20 Old 06-13-2013, 01:27 PM
DMBatCOFC's Avatar
Hey there!
The Best Buy calibration results are drastically different than the setting I provided on this thread, and it looks great! With that being said, I talked to the calibration tech who said that each TV set is different, even if the model numbers are the same. I would highly recommend getting your TV professionally calibrated.
post #18 of 20 Old 06-14-2013, 01:08 PM
haykat's Avatar
haykat is offline
post #19 of 20 Old 07-29-2014, 06:19 PM
Liked: 0
Best Buy Professional Calibration Settings
Hey guys,
Here's my first post as a user on this forum! I had Best Buy do a professional calibration on this TV about a year ago. Here are the settings:
Picture Mode: Expert 1/ Expert 2
Backlight: 100/48
Contrast: 85/83
Brightness: 67/66
H Sharpness: 10/10
V Sharpness: 10/10
Color: 51/51
Tint: R2/0
Expert Control
Color Gamut: Standard
Color Temp: Warm/Warm
Gamma: 2.2
Method: 2 points
Points: Low
Red Contrast: -2
Green Contrast: 0
Blue Contrast: 4
Points: High
Red Brightness: -14
Green Brightness: 0
Blue Brightness: -35
I hope someone finds this useful.
radio5 is offline
post #20 of 20 Old 08-07-2014, 05:53 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Originally Posted by radio5 View Post
Hey guys,
Backlight: 100/48
Contrast: 85/83
Brightness: 67/66
H Sharpness: 10/10
V Sharpness: 10/10
Color: 51/51
Tint: R2/0
Expert Control
Gamma: 2.2
Method: 2 points
Points: Low
Red Contrast: -2
Green Contrast: 0
Blue Contrast: 4
Points: High
Red Brightness: -14
Green Brightness: 0
dunno about the 60+ brightness man
Leonheart is offline
Reply 3D Displays
Lg , Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Lcd Hdtv
