Will my projector be able to display 3D? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2012, 06:08 AM - Thread Starter
Rotary syntax's Avatar
Hello.
I have a 3D ready projector I'm planning on using with my computer. I gather that an HDMI cable is required to display 3D, which I have, but the problem is that my graphics card does not have an HDMI output, only DVI.
My question is: to display 3D, can I use the HDMI cable with a DVI adapter at the GPU, or do I have to get a new graphics card with native HDMI support?
Rotary syntax is offline
Old 05-07-2012, 07:03 AM
Bob7145's Avatar
Liked: 36
You can do 3D with VGA but Hollywierd won't let you. I use a DVI to HDMI cable to my projector but a DVI to HDMI adapter should work.
Edit: Do you have some software to play 3DBD?
Bob7145 is offline
Old 05-07-2012, 07:28 AM - Thread Starter
I'm not familiar with the term 3DBD. Are there issues with using a computer as a 3D player?
Thanks for the answer by the way.
Old 05-07-2012, 08:58 AM
Bob7145's Avatar
Liked: 36
3DBD = 3D Blue Disc
You need some kind of software to play BD (BluRay)
A BD drive and a graphics card capable of Stereo3D.
Graphics cards for 3D gaming have been around for over a decade but Stereo3D is something else. 3DBD are Stereo3D. Only graphics cards made in the last couple of years can handle Stereo3D.
Bob7145 is offline
