Oculus Rift is an HMD with an Immersive 90-degree FoV, to be funded by Kickstarter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 41 Old 05-30-2012, 01:55 PM - Thread Starter
benz145's Avatar
Some smart guy from the MTBS3D forum has working prototypes of an HMD with a 90 degree field of view for immersive 3D gaming. He's hoping to crowd fund the project with Kickstarter to create an upgradeable HMD kit with a target price of around $500. What's even more interesting about this is that John Carmack of Id (Doom, Wolfenstien, etc.) fame has apparently taken great interest in the HMD (called the Oculus Rift) and has been testing it with Doom 3 BFG which is set to release later in the year. Carmack says that Doom 3 BFG will have full support for existing HMDs and for the Rift's high field of view.
The Verge ran a story earlier about it (link included in the story below), but it felt like it was missing a lot of backstory about the Oculus Rift itself so I went digging and here's everything that I found:
http://roadtovr.wordpress.com/2012/0...kstater-video/
benz145 is offline
post #2 of 41 Old 05-30-2012, 02:04 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Now THAT's interesting! While HMDs from Sony and Silicon Micro Display are nice you can't call them a virtual reality headsets because of their 40-45 degree FOV. I was waiting for this.
Elix is offline
post #3 of 41 Old 05-30-2012, 02:09 PM
m. zillch's Avatar
Quoted: 1868 Post(s)
Liked: 1192
Thanks, benz.
"While the FoV is great, the Oculus Rift is still a very early prototype and has some issues, the biggest of which is a low resolution. The display is a single 1280×800 panel which devotes half of itself to each eye making the effective resolution 640×800 far behind the ST1080′s 1080p displays and the HMZ-T1′s 720p OLED displays."
I'm not a gamer, I'm a movie and TV watcher, but I can tell you that even if such a device were to upgrade to use Full HD, 1080x1920 panels, eventually, that's simply not enough pixels for a massive 90 FOV. It would be like looking at a giant image of individual dots.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #4 of 41 Old 05-30-2012, 02:33 PM - Thread Starter
benz145's Avatar
Originally Posted by m. zillch View Post
Thanks, benz.
Yeah the resolution is certainly a concern. Carmack says from his testing that "The resolution is low for this large of an FOV; you can definitely see the pixels, and most people who have tried it on have commented about it relative to the HMZ-T1 that they had seen before. With such large pixels you want to take extra care to avoid aliasing - I wound up supersampling a fair amount in addition to using 4x MSAA for best results."
The issue, as I see from what I've read about this, is that the display they are using is the right size and there isn't a good mass produced alternative with a higher resolution. From what I gather, the Rift is using a single display panel (like what you'd find on a smartphone) rather than individual microdisplays like the HMZ-T1 or ST1080. If they could find a reasonably priced and appropriately size alternative, I'm sure they'll put it in. A 1920x1080 panel would mean effectively 960x1080, which would be pretty good.
benz145 is offline
post #5 of 41 Old 06-02-2012, 11:00 AM
mellott124's Avatar
That kind of resolution spread over that wide of a FOV is going to look horrible.
You need to think of it this way, that's 600x800 spread over twice the FOV of the HMZ-T1 or ST1080. Now your pixels are going to be twice as large. You can't get twice the FOV with half the resolution and expect it to be anywhere near the quality of the HMZ-T1 or ST1080. People will quickly berate the device once they've gotten over the FOV.
You'll be legally blind with this HMD. Like the HMDs in the 90's.
mellott124 is offline
post #6 of 41 Old 06-03-2012, 05:13 PM
rjyap's Avatar
The target group for this hmd are gamers, not movie lovers. The pixel will be stretch horizontally by the lens more on the edges.
rjyap is offline
post #7 of 41 Old 06-03-2012, 05:33 PM
nickoakdl's Avatar
Quoted: 76 Post(s)
Liked: 62
Since when don't gamers care about resolution?
nickoakdl is offline
post #8 of 41 Old 06-04-2012, 01:18 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
The author is going in the right direction with these. I'm sure John Carmack does know a thing or two about 3D entertainment.
But I'm afraid this first model won't be perfect (have high enough resolution) simply because of insufficient financing. How well it goes afterwards depends solely on how it will be accepted and supported (financially) among consumers and representatives of industry (such as Carmack).
Just being Cpt.Obvious here.
Elix is offline
post #9 of 41 Old 06-04-2012, 09:04 PM
tory40's Avatar
The resolution is a huge negative, especially that resolution, but i currently play at 720p on a 46" 3dtv which gives me a FoV of about 82 degrees, which has less than half of the pixels of 1080p and its a greater experience than 2560x1600 on a 30" Dell in 2D. That said, since gaming at 1080p in 3D is not much more demanding than 720p, i'd try very very hard to find a manufacturer that would sell small 1080p LCDs, or even oleds, cheaply. 640x800 is kind of a step backward. I can already pull my monitor or 3DTV closer to get a 90 degree FoV.
tory40 is offline
post #10 of 41 Old 06-06-2012, 01:09 PM - Thread Starter
benz145's Avatar
Some new details about the Oculus Rift including a target price of $500 for the kit!
http://roadtovr.wordpress.com/2012/06/06/early-oculus-rift-specifications-and-official-site-confirms-500-target/
benz145 is offline
post #11 of 41 Old 06-08-2012, 12:45 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
At 500$, this awesome piece of hardware is a must-have for an enthusiast gamer. Also, nice logo.
Elix is offline
post #12 of 41 Old 06-08-2012, 09:45 AM
m. zillch's Avatar
Liked: 1192
Originally Posted by tory40 View Post
i currently play at 720p on a 46" 3dtv which gives me a FoV of about 82 degrees.
Out of curiosity, do you watch TV and movies at a 23" distance from your 46" display, as well? Or just games?
post #13 of 41 Old 06-08-2012, 06:06 PM
Palmer Luckey's Avatar
It is actually not as bad as you think. The optics compress the image in a way that gives you more pixels in the center, and fewer in the periphery. Heck, you give a pretty good review on your own site to the MRG2.2, and the Rift has a pixel density several times greater than that, and weighs 90% less to boot! wink.gif
It is not meant to compete with the ST1080 or the HMZ-T1, those are both still great products with a ton of great qualities. I am biased, obviously, but I think the Rift is great for what it is: A high FOV, lightweight, easy to modify HMD kit for VR enthusiasts.
Palmer Luckey is offline
post #14 of 41 Old 06-09-2012, 01:39 PM
tory40's Avatar
Lol, no, just games, and i increase the rendering field of view in the games settings as well. For movies, i'll watch in a window or back up and relax on my couch. In games, i can lean forward and the depth diminishes, but things look closer, which is sometimes a good thing.
tory40 is offline
post #15 of 41 Old 07-30-2012, 10:01 PM - Thread Starter
benz145's Avatar
The Oculus Rift Kickstarter is going to be launching really soon! I just pulled together all the latest info here:
http://www.roadtovr.com/2012/07/30/oculus-rift-kickstarter-watch-prototype-and-other-updates/
benz145 is offline
post #16 of 41 Old 08-03-2012, 08:10 AM
iaTa's Avatar
Amazing response so far.
I've pledged $330 for the dev kit.
iaTa is offline
post #17 of 41 Old 08-03-2012, 09:49 AM
Skylinestar's Avatar
Quoted: 1056 Post(s)
Liked: 184
I hope the final version works good on HD movies besides over emphasizing on pc gaming.
Skylinestar is offline
post #18 of 41 Old 08-04-2012, 01:23 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Elix is offline
post #19 of 41 Old 08-05-2012, 09:21 AM
rjyap's Avatar
The creator, Palmer had mentioned the initial version will only support games with pre-warp image built-in. The first game to support it would be DOOM3:BFG version. He even mentioned multiple times to discourage average consumer not to set that expectation that the unit can be use for 3D movie (unless you can use shader to warp the final image in SBS mode) or standard commercial game. If you are expecting a perfect HMD, then this is not for you.
rjyap is offline
post #20 of 41 Old 08-20-2012, 05:58 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Oculus Rift kickstarter - 11 days to go.
http://www.kickstarter.com/projects/1523379957/oculus-rift-step-into-the-game?ref=live
Also, this thread's name has to be edited - Rift has a 110-degree FOV.
Elix is offline
post #21 of 41 Old 09-04-2012, 01:20 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Kickstarter has ended with 9,522 backers. $2,437,430 pledged of $250,000 goal! There's no reason not to succeed with 10 times more funding than planned. Anyone on this forum expects a developer set?
Elix is offline
post #22 of 41 Old 09-04-2012, 06:48 AM
iaTa's Avatar
Yep I'm in. Can't wait.
iaTa is offline
post #23 of 41 Old 09-07-2012, 03:07 PM
muterobert's Avatar
Yup, I'm in too. Actually, I pledged for a headset on the first day - such was my excitement. Personally I think it has the potential to be the most significant step forward in interactive entertainment in my lifetime, or it could be a horrible disaster! wink.gif
Anyway, to channel my new obsession into something useful, I went and created my first ever website: www.riftvr.com
.. might be of interest to some of you. Or not.
Anyway, December cannot be here soon enough. Best. Xmas. Pressie. Ever! smile.gif
muterobert is offline
post #24 of 41 Old 09-11-2012, 07:26 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Elix is offline
post #25 of 41 Old 01-27-2013, 08:58 PM
cakefoo's Avatar
Quoted: 179 Post(s)
Liked: 70
I preordered a dev kit!
https://www.oculusvr.com/pre-order/
My computer sucks, but I can run Valve games in stereo, that I know for sure. I might have a new PC by April anyway.
Oh, and they're going to show the Rift on Jimmy Fallon Wednesday night. He always reacts over the top with stuff so it'll be fun to see this one, since even the authentic reactions to the Rift have been pretty emotional!
cakefoo is offline
post #26 of 41 Old 01-28-2013, 07:54 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Quite a lot of people preordered it but we haven't seen any impressions yet.
Post a link for us afterwards, ok?
Elix is offline
post #27 of 41 Old 02-04-2013, 01:20 PM
Devedander's Avatar
Quoted: 16 Post(s)
Liked: 36
And I'm glad he did...
I would have been in on this except for that fact.
I can handle low res, no biggie for me but I need the option to use it on a lot of content...
Shame and hopefully they resolve the resolution issue reasonably soon as I am in for one that supports a broad range of products even at 720p 90fov.
Monster Gold Plated Optical Cables: http://monstercable.com/productPage.asp?pin=1263
Awesome user review: "Unreal quality. Sounded like I upgraded my speakers." :D
Devedander is offline
post #28 of 41 Old 03-05-2014, 07:49 AM
kovacp1's Avatar
Wow, you are correct.
The resolution is so low I cannot see this device being used for gaming, etc.  When you wear it, the scene is so 'smeared' it is disconcerting.
It is too bad, as this had potential.
The other problem is that there is enough lag that there is a very strong likelihood people will become ill using this in extended duration gaming, etc  And this is running on a high end machine with the best graphic card
This is very much a slightly updated version of the HMDs we created in the 1990s.  The resolution is the same and apparently lessons were not learned from those days
Hopefully a new high resolution version will come out and be offered inexpensively to initial adopters soon!
kovacp1 is offline
post #29 of 41 Old 03-05-2014, 11:43 PM
perkele's Avatar
Come on man, its a DEV KIT for a reason. Oculus HAS, not had, a true potential, first consumer grade model will be many times better than the prototype. Why do you think they didnt go to the consumers with their 720p model? They've party solved the resolution and pixel grid. New oled prototype has 1080p screen and oled has higher pixel fill rate so it has less grid on same resolution than the lcd screen they are using on that 720p dev kit. Also the low persistance mode(strobe backlight) solves the smearing, nausea, fatigue and motion blur problem almost completely.
perkele is offline
post #30 of 41 Old 03-08-2014, 05:30 PM
TonyDP's Avatar
Quoted: 306 Post(s)
Liked: 201
Forgive me if I seem a little dense but it feels like I've been reading about the Oculus Rift's development and pending consumer release for 5 years (yes, that is a deliberate exaggeration done for dramatic effect). All the stories about the wonderful things people are doing with the dev kits are interesting but is there some semi-concrete info on when the consumer version will finally be released?
Xbox Live: XboxPhantom
PSN: TonyDP
TonyDP is offline
Reply 3D Displays
Oculus Rift Developers Kit , Mitsubishi
