Asus VG23AH - User reviews? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-01-2012, 05:31 PM - Thread Starter
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
I read the CNet review of the 23" Asus VG23AH IPS passive 3D display, and their review of the 3D was particularly scathing.
The problem is, I haven't been able to find any other review of this monitor than the one that CNet did. Every other tech site on Google is simply reposting CNet's review. I have a feeling this review may have singlehandedly killed this product, and I have a feeling that the guy writing the review may not have known what he was talking about.
Anyway, the thing that they complained about the most was ghosting when playing games in 3D (they didn't try watching 3D video content, which is somewhat telling in itself). I was under the impression from some of the other threads around here that there are settings in both hardware and software (image adjustments, effects, etc) that, if incorrectly configured, can cause some bleedover to the adjacent horizontal lines, and can cause exactly the ghosting that they're referring to. Or, something as simple as having the wrong polarization on the glasses. But I can't find any actual user reviews to back this up, that maybe someone bought the thing, configured it correctly, and the 3D effect works perfectly fine, or whether the panel really is a piece of crap.
I'm in the market for a new computer monitor, and I've decided on two things: Passive display and IPS. Right now, I think the Asus is the only Passive IPS display out there (maybe the only 3D IPS out there.. can IPS do 120Hz+?). I know LG has a few in the pipe, but there's no telling how long until they're released, and I'm worried that the problem with the underlying panel may carry over to the newer ones as well (anyone know if that's a LG panel in the Asus?)
The other thing I've seen come up in reviews all over the 'net, for various 3D displays, is a difference in perceived depth, that a particular monitor's 3D display isn't as "deep" as others. From what I know of 3D technology (and I've created 3D images in CG), how is that even possible? Depth is controlled exclusively by the separation of left/right eye images, which is controlled 100% by the imaging software feeding the monitor, and not the monitor itself. I'm guessing that the reviewers in this case never thought of looking at different displays without glasses and seeing if the software, for whatever reason, was displaying more or less separation between different hardware (I always calibrate convergence without glasses, so I'm familiar with what a "raw" 3D image looks like). I'm not wrong here, am I?
Thanks ahead of time.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
post #2 of 12 Old 06-01-2012, 10:56 PM
hillyerm's Avatar
The Asus VG23AH manual and the European review below both state that the VG23AH real 3D requires an HDMI cable and HDMI 1.4 compatible graphics. The CNET review said they tested with the DVDI input. Therefore the CNET tests of the VG23AH's 3D are invalid.
Other review: http://translate.google.com/translat...asiv-review%2F
The VG23AH manual can be found here: http://www.asus.com/Display/LCD_Moni...23AH/#download (choose Others for OS)
I did try emailing the CNET guy about it but he never replied.
hillyerm is offline
post #3 of 12 Old 06-02-2012, 08:55 AM - Thread Starter
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Thanks for your input. My card has a HDMI 1.4 port on it, that's what I was going to use on my next monitor anyway (keep my current monitor on DVI for dual-screen, but not for gaming).
It's somewhat telling about the reviews I was reading that so many people out there don't seem to have the slightest idea what they're talking about, and yet they're considered the "experts". CNet seems to have screwed up the configuration on their review setup, and everyone else across the internet is simply taking their word for it.
Jedi2016 is offline
post #4 of 12 Old 06-21-2012, 11:54 PM
hillyerm's Avatar
hillyerm is offline
post #5 of 12 Old 06-22-2012, 10:26 PM - Thread Starter
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Thanks. I actually took a chance.. I've had this monitor for a couple of weeks now.. hehe. That review hits it right about on the head. Performance is pretty good, and I'm enjoying it quite a lot on the games that really benefit from it. That also brings up a good tip to reduce the "after image" type ghosting that I see in certain games. I had thought it was a problem with refresh rate (being an IPS display), but looks like there's a setting that affects it. I'll have to give that a whirl tomorrow and see if it makes a difference.
And yes, the glasses are RealD3D compatible. The ones that come with the monitor are far more comfortable than the ones at the theater, I used these to watch Prometheus. The clip-ons leave a bit to be desired, though.. the clip is so large that it presses against that spot right between my eyes.. I can't wear them for more than a few seconds without going batty.
I can write up a longer review if you like, but bear in mind that I have no frame of reference on the performance, as this is my first 3D monitor. I know how the technology works, I just don't have a frame of reference to make comparisons to other passive monitors, or active-shutter monitors.
Jedi2016 is offline
post #6 of 12 Old 07-09-2012, 01:14 PM
aaronraw's Avatar
I just gont one, and while I like it, I have it hooked up to an ATI 6970 with a 1.4 HDMI and Im getting a double image with the glasses+3D on. Has anyone had luck with it and ATI cards? What could I be doing wrong? Let me knw plz! Thanks!
aaronraw is offline
post #7 of 12 Old 07-10-2012, 09:16 PM - Thread Starter
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Check your viewing angle, passive is highly dependent on vertical angle because of how the pixels and the retarder layer lines up. If I sit at my normal "working" height like I am now when I'm writing, it doesn't line up properly and it's like I don't even have the glasses on. But if I kick back into my more "relaxed" posture, the 3D works fine. I think it's about 10-15 degrees off center. I just tested it on mine, and if viewed from absolutely head-on, the effect is pretty decent, but I usually view it from a slightly lower angle.
Put on a 3D YouTube video, sit back about four or five feet away, and just move up and down until you find the "sweet spot". Then adjust the monitor so that's the angle you're at in your normal viewing/gaming position.
I'm not sure how it is on ATI cards, I'm using NVidia here, and it's built into the drivers, so I don't have to worry about third-party software or anything. Make sure the output is set up correctly, interleaved, etc, and make sure your resolution matches. The desktop resolution has to exactly match the resolution of the display in order for things to line up properly.
Jedi2016 is offline
post #8 of 12 Old 09-03-2012, 02:35 AM
hillyerm's Avatar
hillyerm is offline
post #9 of 12 Old 09-07-2012, 01:38 PM
virsat's Avatar
I'm really interested in this monitor and have been trying to find out something about it. Does the regular nVidia driver recognize the ASUS VG23H for it's 3D mode? nVidia's site says only two particular models of Acer are officially supported for the passive 3D effect. If I can plug this monitor into my GTX 660 Ti and have the latest nVidia drivers automatically recognize it for full 3D support I will buy it absolutely, but I can't find any verification of that so far.
virsat is offline
post #10 of 12 Old 06-04-2013, 05:52 AM
Mike507's Avatar
I just bought asus VG23AH.I am happy with the picture,the 3d works fine .bought from amazon.com used for 141.00 I have no complaints I really do believe the guy who came up with this review had his head up his a---.it switches to 3d with toch of button,ive played games,cod 234,world of tanks,world of warplaces,black ops,browsed the web all in 3d.this monitor is the best ive ever owned.for people to take the opinion of one man just because he works for cnet is crazy.ck it out for your selves this monitor rocks.
Mike507 is offline
post #11 of 12 Old 08-15-2013, 08:02 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
It´s great monitor if you buy the tridef software and use those drivers in games. eather use rgb mode with hdmi cable and get cutout on black and highs or use the ycrcr444 and adjust the stereo seperation to 9-12 with tridef. not as imersive but atleast you get good about ghost free 3d experience. by the way the clipon gives better extinction course you can tweak the angle of polarizer and the display.
Vaan Janne is offline
post #12 of 12 Old 09-27-2013, 01:05 AM
cakefoo's Avatar
Quoted: 179 Post(s)
Liked: 70
My computer just has a VGA output. Since the monitor requires a DVI or HDMI signal to enable 3D, what kind of adapter could I get?
edit: Checked the back of my PC the next morning and I do have an HDMI port. I even have an HDMI cable plugged in going to my other screen. I'm so forgetful!
cakefoo is offline
Reply 3D Displays
Asus , Asus Vg Vg23ah 23 Inch Screen Led Lit Monitor , 3d Hdtv , Displays , Nvidia
