3D Projector going to work in Theater? - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2012, 07:03 PM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
So I am planning my theater and am unsure on something...
My front row is going to be about 14' away from the screen. Is this going to be too far for any 3D possibilities? I was planning on a 5010 Projector with 2.4 High Power Screen.
crakerhead is offline
Old 06-08-2012, 05:37 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
For a 14 ft. viewing distance you should consider at 120" to 135" screen (diagonal). Rule of thumb for 1080p resolution is 1.5X the screen width, but some people like to sit as close as perhaps 1.2X screen width (especially for watching 3D). For example a 120" diagonal 16x9 screen is approx. 105" wide therefore 1.5X this value would be approx. 158", or just over 13 ft.
You should post your question in the Display Devices >> Digital Projectors forum here at AVS. There is a separate section for projectors under $3K and another section for projectors over $3K, There is lots of threads on 3D projectors including comparisons and various post about screens for use with these projectors. You may also want to check out projectorreviews.com.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
