3D TV recomandation for total newbie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-19-2012, 06:43 AM - Thread Starter
regulament's Avatar
Ok, my old(4 years) LCD TV needs to be replaced. As I am a total newbie, I need some advice on what to buy.
- between 102 cm(40 inches) and 140 cm(55 inches). 110 cm(43 inches) seems perfect, but I'm flexible.
- the distance to the TV is about 3m(about 9 ft)
- 3D is a must, and 4 glasses at the same time should be supported
- no preference regarding, LCD, LED, Plasma, DLP. Plasma seems great tough.
- no preference regarding internet, apps, widgets and so on
- the TV will be used to watch mainly SD TV shows(little HD broadcasting) and about 2 times a week Full HD/Full HD 3D movies(downloaded from the internet, no BluRay)
- budget: <= 1.200$ and I live in Europe
I look forward to your responses and I thank you beforehand for your suggestions.
regulament is offline
post #2 of 3 Old 06-21-2012, 09:06 AM
Ikari Warrior's Avatar
Quoted: 177 Post(s)
Liked: 103
I don't know which models are available in Europe but I'd go with an LG or Vizio passive set, either 42" or preferably 47"...either should fulfill your requirements for number of viewers and your budget. I have both a 47" and 65" Vizio passive set and they look incredible.
Xbox Live gamertag: Ikari Warrior
Playstation Network ID: IkariWarrior
Ikari Warrior is offline
post #3 of 3 Old 06-21-2012, 02:28 PM
bravia3D's Avatar
Liked: 33
I'd suggest the same, LG would be great for you as you can have many viewers with cheap glasses and amazing 3D.
3D items I own:
Sony 46" LX900 active 3D set
Sony HMZ-T3 (Cushion pads and light blocker mod)
LG LW6500 passive 3D set
PS3 & PS4
Sony BDP-S570 BD3D player
JVC-GS-TD1 (with Cyclopital base extender)
Fujifilm W3
Sony Alpha 55 (for 3D panoramic photos)
Quadcopter + Zenmuse and GoPro Hero 3 (Filming...
bravia3D is offline
Reply 3D Displays
