want to make sure i ordered everything i need for my wd60737 for 3d - AVS Forum | Home Theater Discussions And Reviews
Old 06-20-2012, 08:38 PM - Thread Starter
orguss1's Avatar
So i have had my wd60737 for a while and now want to make the jump to 3d. I ordered the panasonic dmp-bdt320 which is supposed to do checkerboard. And order 6 pairs of xpand 102 revolution dlp link glasses.i assume this is all i need and will my mirror crack be a problemwith 3d until i fix it.
Hope i got everything. Let me know if iam missing anything
orguss1 is offline
Old 06-22-2012, 11:26 AM
xpandsupport's Avatar
Mitsubishi WD737 is a 2009 3d DLP It is "3D ready" but doesn't have a built-in 3D decoder. for this TV you will need a 3da-1 adapter and ask Mitsubishi as well for any new firmware updates for the TV. this is the link for the 3da-1 adapter http://www.mitsubishi-tv.com/accessory/3DA-1 also 3dglassesunlimited is selling the 3da-1 adapter here is their number (800)918-5390 and the direct link in their website http://www.3dglassesunlimited.com/mitsubishi-3d-adapter-3da1-for-mitsubishi-dlp-3d-ready-hdtvs-p-78.html?osCsid=abd5f6508379aada7b8d9fe23e237006.
xpandsupport is offline
Old 06-22-2012, 03:45 PM
GEP
GEP's Avatar
The most current software is avaliable for download via the Support section of the Mitsubishi web site www.mitsubishi-tv.com.
However, yes for your Bluray player you do not need the adapter because that bluray player does convert to the checkerboard format. You do need the adapter for DirecTV, cable or other brands of bluray players that do not convert to checkerboard.
GEP is offline
