How do these specs compare for a 47" display? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-30-2012, 11:27 AM - Thread Starter
lasitter's Avatar
I'm still looking for more reviews on this panel, and without reviews to consider I thought I would just ask about how the panel specs compare to others in the 47" range (my max for space reasons):
LG 47LD950C
LG 47" 3-D Ready 1080p 240Hz LCD Commercial Widescreen HDTV 47LD950C
General
Brand
LG
Model
47LD950C
Cabinet Color
Glossy Black
Panel
Screen Size
47"
Recommended Resolution
1080p
Maximum Resolution
1920 x 1080
Aspect Ratio
16:9
Viewing Angle
178°(H) / 178°(V)
Display Color
16.7 Million (10 Bit)
Brightness
400 cd/m2
Dynamic Contrast Ratio
100000:1
Panel Life
50,000 hrs(Typical)
Response Time
4ms
Video
3-D Ready
Yes
3-D Glasses Included
Yes
Refresh Rate
240Hz
User Settings
Aspect Ratio Correction: 6 Modes
Color Temperature Control: 3 Modes (Warm, Med, Cool)
AV Mode II (Picture & Sound): 3 Modes (Cinema, Sport, Game)
EZ Picture/PSM: 7 modes
V-Chip
Yes
Tuner
ATSC/NTSC/QAM Tuner
Enhanced Motion
TruMotion 240Hz
Video Processor
XD Engine
Support Video Signal
1080i/p, 720p, 480i/p
Audio
Built-in Speakers
Invisible 2-Way 4 Speaker
Speaker Location
Bottom
Output Power
10W + 10W
Simulated Surround
SRS TruSurround XT, SRS WOW
Connectivity
HDMI
3 (rear), 1 (side)
PC Input
15-Pin D-Sub x 1
USB
Yes
Composite A/V
2 In
Component Video
1 In
Digital Audio
1 Optical Out
Other Connectors
1 x RF In (Antenna/Cable)
1 x PC Audio Input
1 x RS-232c In
Power
Power Supply
100V - 240V, 50/60 Hz
Power Consumption
304W
Convenience
VESA
200mm x 200mm
Stand
Swivel Stand (+20º/-20º)
User Controls
Language: English/Spanish/French/Korean
Alvin UI
Auto Tuning/Programming
Channel Add/Delete
Favorite Channel Programming
Auto/Manual Clock
On/Off Timer
Sleep Timer
Remote Control
Yes
Feature
Just Scan (1:1 Pixel Matching): 1080p (HDMI, Component)/ 1080i (HDMI, Component, RF) / 720p (HDMI, Component, RF)
Enhanced Noise Reduction (Video Noise Filter)
3D Digital Comb Filter
Black Stretcher
24p Real Cinema
Cinema 3:2/2:2Mode
Picture Reset
ISFccc Ready
DTV Signal Strength Indicator
Video Reset/Initializing
Invisible Speaker System
Dolby Digital 5.1 Decoder
Bass/Treble/Balance Controls
Clear Voice II
Auto Volume Leveler
5 EZ Sound Mode/SSM Modes
PDM2.4 Public Display Settings
Energy Saving Modes
Brightness Optimization (Available in Standard, Natural, Sport, Game modes)
Backlight Control
USB Cloning
1080p Source Input: HDMI (60p/30p/24p): Component (60p/30p/24p): RGB (WXGA)
A/V Input Navigation
Input Labeling/Sub-title
Discrete IR Codes
Quick View (Previous Channel)
Quick Setup Guide
e-Manual
Parental Control w/V-Chip
Key Lock/Child Lock
Customizable Closed Caption/Sub-title
lasitter is offline
post #2 of 2 Old 07-01-2012, 08:31 AM - Thread Starter
lasitter's Avatar
Never mind. Bought: LG 47LM6200
The model I was asking about claimed a 240Hz refresh rate, but came with SCART connectors because it was it was a model often used in UK / Europe.
It also lacked any number of more recently introduced whiz-bang features of the 120Hz newer set.
lasitter is offline
Reply 3D Displays
