TruMotion doesn't seem to work in 3D on my LG 55LM7600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-07-2012, 04:05 PM - Thread Starter
Doc M's Avatar
All levels of TruMotion work as expected in 2D but none of them do anything when playing a 3D Blu-ray. Can a lover of the SOE please look for this and verify? It's an LG 55LM7600.
BTW, i am amazed how few SOE artifacts this set has compared to my 3 year old Sony KDL-65W5100 with Motionflow.
Doc M is offline
post #2 of 6 Old 07-07-2012, 06:03 PM
walford's Avatar
Set the truMotion intensity value to the lowest value to reduce artifacts.
Tru motion is not available when in 3D because the TV can not display both screens and insert a black frame( or frame scan) after each frame in 3D and have any time left to insert an interpolated frame even with a 240Hz LCD TV.
walford is offline
post #3 of 6 Old 07-07-2012, 09:01 PM - Thread Starter
Doc M's Avatar
Thanks. Is that true of all active & passive 3D sets when playing the SOE?
Doc M is offline
post #4 of 6 Old 07-08-2012, 08:45 AM
walford's Avatar
That I am not sure of. It should not be a problem on displays higher then 240Hz but may be.
walford is offline
post #5 of 6 Old 07-10-2012, 12:14 PM
Butmuncher's Avatar
As far as i'm aware all of lg's 2010/2011 3d passives was the only passive 3dtv's on the market that had interpolation active in 3d.
I've had a few lg's and a few other passives from other manufactuers, the only reason i go lg for the last few years was because of motion interpolation in 3d wink.gif.
Maybe lg have messed up, maybe you need to change settings in 3d, dno.
I do know i was looking at getting the uk's counterpart this weekend so this news is disturbing if it is'nt a user error or firmware error.
Bugged Interleaved/checkerboard lg forum thread, please add your names.http://www.avforums.com/forums/lg-fo...-lg-3dtvs.html
Butmuncher is offline
post #6 of 6 Old 07-10-2012, 07:53 PM - Thread Starter
Doc M's Avatar
I'll check tomorrow & make sure mine has the latest firmware/software updates and report back.
Doc M is offline
Reply 3D Displays
Lcd Hdtv , Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , 3d Hdtv
