Alternatives to 3DA-1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-07-2012, 05:17 PM - Thread Starter
kipz's Avatar
I have a Mitsubishi 65737 and finally decided to look into using it for 3D. I've found that the 3DA-1 is selling $400 and the starter kit for $430. So I'm just wondering if there are any other products I could get that would convert the 3D for me without the high price.
kipz is offline
post #2 of 5 Old 07-08-2012, 09:49 AM
walford's Avatar
Depends on what your 3D source is. If your source can provide 3D in Checkerboard format then you do not need an adapter which converts to Checkerboard.
walford is offline
post #3 of 5 Old 07-10-2012, 02:10 AM - Thread Starter
kipz's Avatar
Sorry, I should've clarified. I'd want to use it for my Xbox 360 and PS3, I understand that they need a converter but I was wondering if maybe there are any third party ones so that it wouldn't be so expensive.
kipz is offline
post #4 of 5 Old 07-13-2012, 03:49 AM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
The 3DA-1 lists for $99. Unfortunately, they are discontinued, so there is price gouging going on. Try ebay, or ask around in the rear projection forums. Some people may have upgraded to a newer TV and have the adaptor for sale.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #5 of 5 Old 07-14-2012, 10:20 AM
lewis3845's Avatar
I believe you can also use the 3DC-1000 and it comes with 2 pairs of glasses. I've seen them on sale for $150 before but they usually are in the $200-$300 range and also check e-bay I seen a 3da-1 and bidding was at $30.
lewis3845 is offline
Reply 3D Displays
3d Hdtv , Mitsubishi , Playstation 3 160gb System , Displays
