Which 3D monitor should i get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-21-2012, 09:46 AM - Thread Starter
mayorice's Avatar
i am mainly using it for gaming and movies.
and i am torn between Viewsonic V3D231 , AOC e2352Phz and LG D2342P-PN
If i'm not wrong, all 3 of them uses passive 3D right?
And is there a minimum distance for using 3D? since i don't think i can change that distance of my monitor smile.gif
i also heard they uses tridef which does not support 64bit pc, is that true?
mayorice is offline
Reply 3D Displays
