Sony HMZ-T2 Personal 3D Viewer HMD Dedicated Thread - Page 39 - AVS Forum | Home Theater Discussions And Reviews
post #1141 of 1154 Old 09-26-2014, 08:43 AM
Liked: 0
Hi guys!
Have anyone of you managed to add custom resolutions to the HMZ-t2? Meaning that you pushed the 60hz refresh rate to above and beyond?
I am trying to get +60hz in 2D mode.
Best regards
Victor
vbs1214 is offline
post #1142 of 1154 Old 09-30-2014, 10:38 PM
ElGreat1's Avatar
You may don't want to do that since it can mess up the OLED. Sony HMZ-T2 OLED is 60hz, anything higher can mess it up.
ElGreat1 is offline
post #1143 of 1154 Old 04-22-2016, 11:57 AM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
Any idea how to watch the VR videos properly on a HMZ-T1/2/3?
Skylinestar is online now
post #1144 of 1154 Old 04-24-2016, 12:30 AM
Liked: 0
Send me some VR video samples to try on my HMZ-T3W
avegant is offline
post #1145 of 1154 Old 05-02-2016, 08:03 AM
Liked: 0
I am able to watch the clips properly by setting the 3D display as "Side By Side".
avegant is offline
post #1146 of 1154 Old 10-22-2016, 01:44 PM
jimlau's Avatar
Quoted: 23 Post(s)
is the HMZ-T2 headset compatible with HMZ-T1 box?
jimlau is offline
post #1147 of 1154 Old 11-06-2016, 08:41 AM
Liked: 0
i would like to know too. i have a HMZ-T2 headset and HMZ-T1 box with me. they are random items in the warehouse where i work. when i connect them together, it refuse to switch on. i dont know if they are faulty or just incompatible.
reddemonic is offline
post #1148 of 1154 Old 11-19-2016, 07:00 PM
jimlau's Avatar
Quoted: 23 Post(s)
Can't use with a PC?
I used an HMZ-T1 as the display for my PC. But it is not working now with an HMZ-T2, with the exact same set-up. It says "No signal." Any ideas why not?
jimlau is offline
post #1149 of 1154 Old 11-20-2016, 06:47 PM
Liked: 0
hi jimlau
does the HMZ-T2 headset work on HMZ-T1 processor unit? thanks
post #1150 of 1154 Old 12-09-2016, 07:54 AM
mashakos's Avatar
So I messed up...
I used lens cleaning fluid on my hmz t2. Now the screen is blurry at the edges. Is there a way to open up the unit and clean the lenses from the inside...?
mashakos is offline
post #1151 of 1154 Old 12-09-2016, 07:55 AM
mashakos's Avatar
I had the same problem at first and it turned out to be my HDMI cable. Changed it and the unit worked fine.
mashakos is offline
post #1152 of 1154 Old 12-09-2016, 08:46 AM
jimlau's Avatar
Quoted: 23 Post(s)
If it was an HDMI cable problem, why does the Blu-Ray work? actually there are 2 cables in that instance.
Anyway, I got another T1. A problem yet again. This time I can't get past the welcome screen, to the adjustment screen (i.e. several steps before getting any no signal message). Seems essentially as if the buttons (except the power 1) are non-responsive. That can't be an HDMI cable problem, right? My first T1 worked, but eventually this same thing happened - non-responsive buttons.
jimlau is offline
post #1153 of 1154 Old 12-09-2016, 08:51 AM
Paul H's Avatar
Quoted: 33 Post(s)
Liked: 29
I got another T1. Problem yet again. This time I can't get past the welcome screen, to the adjustment screen (i.e. several steps before getting any no signal message). Seems essentially as if the buttons (except the power 1) are non-responsive. That can't be an HDMI cable problem, right?
Had this happen to me. Pushing the HDMI headset cable securely into the jack corrected my problem.. Cleaning contacts may also help.
Paul H is offline
post #1154 of 1154 Old 12-09-2016, 08:54 AM
jimlau's Avatar
Quoted: 23 Post(s)
Originally Posted by reddemonic View Post
hi jimlau
I don't think so. My system wasn't working properly, but there seemed to be an issue trying to combine the 2.
jimlau is offline
Reply 3D Displays
Sony , 3d Hdtv
