Please!!!! Need help!! With a Mitsubishi wd-60738 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-28-2012, 02:28 PM - Thread Starter
Bellwitch007's Avatar
I purchased the Mitsubishi 60738 and I have the firmware update and now I would like to enjoy 3d content. I do not have the money to spend for the 3d starter pack that Mitsubishi offers. What do I need to get started watching 3d without purchasing the starter pack or the ir emitter?
Bellwitch007 is offline
post #2 of 5 Old 09-28-2012, 04:58 PM
walford's Avatar
AFAIK the x738 series with the firmware update puts the content of the Starter Pack into the x738. Therefor your TV will accept process any content that the starter kit would accept.
walford is offline
post #3 of 5 Old 09-28-2012, 05:31 PM
GEP
GEP's Avatar
You need:
1. 3D source device - 3D Blu-ray player, 3D cable Box, 3D satellite receiver, 3D PS3 game consule - etc.
2. 3D material - 3D Blu-ray disc, 3D channel from cable box or satellite receiver, 3D Game
3. 3D glasses - active shutter glasses - not passive glasses like you get at the theater.
- if you get DLP Link glasses, you do not need any emitter, just turn on the DLP Link in the 3D menu of the TV.
- if you choose IR type 3D glasses you also need the IR emitter that matches the glasses. This plugs into a jack on the back of theTV.
GEP is offline
post #4 of 5 Old 10-02-2012, 10:55 PM
outlawmonster's Avatar
http://3dglassesunlimited.com/3d-glasses-for-mitsubishi-3d-tvs/
This is the best source info I found yet!
outlawmonster is offline
post #5 of 5 Old 10-03-2012, 12:37 AM
DragonSixGolf's Avatar
Liked: 25
$50 glasses AND a $50 emitter? the whole point of DLP link is you don;t need an emiitter, just some $25 DLP link glasses skip the emitter and buy and extra pair of glasses (or two)
DragonSixGolf is offline
Reply 3D Displays
Mitsubishi , Mitsubishi Wd 60738 60 Inch 3d Dlp Hdtv , Lcd Hdtv
