3D movies have darker look - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-30-2012, 10:51 PM - Thread Starter
AndreHD's Avatar
No big deal, but when I'm watching a movie in 2D, the brightness is right. When I put the glasses on and watch a 3D film, it has a darker look to it. Its like I'm watching the movie through sunglasses smile.gif. Samsung un55d6900 by the way. Would one of the picture setting modes help with that?
AndreHD is offline
post #2 of 8 Old 09-30-2012, 11:38 PM
has7738's Avatar
Liked: 24
Probably not. The 3D process needs more light for the same apparent brightness as 2d. Lots more. To the extent that most displays simply don't have that much to give, so 3d looks darker. That's part of the price for 3D, sorry.
has7738 is offline
post #3 of 8 Old 10-01-2012, 12:13 AM
Airion's Avatar
Liked: 61
Isn't there some setting to increase the intensity of the backlight? Just turn that up if possible.
Airion is offline
post #4 of 8 Old 10-01-2012, 12:26 AM
Killerbeenl's Avatar
Isn't that a downside of the dark glasses and actieve 3D TV's?
If the TV is calibrated (for 3D too) it will be a lot better.
Ask any Pro here for more info
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #5 of 8 Old 10-01-2012, 07:08 AM - Thread Starter
AndreHD's Avatar
There is a backlight setting, I'll mess with that some.
AndreHD is offline
post #6 of 8 Old 10-01-2012, 01:08 PM
Don Landis's Avatar
Quoted: 1313 Post(s)
Liked: 373
If you have your TV set for maximum brightness for 2D viewing you can't make it brighter for 3D.
What I do here is calibrate my 2D viewing for a comfortable brightness level. Then in 3D mode I have that boosted to a level where my 2D and 3D are identical. This works for movies that are produced with similar lighting. Some movies are just darker by design. The best way to calibrate this special setting is to use a movie that you own both a 2D and 3D disk and then adjust your screen for equal brightness on both the 2D and 3D, save those settings to a memory.
Now if your screen is too dark already with maximum brightness, you might need to consider a higher quality TV. My projector is so bright in maximum settings for 2D that it would cause headaches so making the matched brightness is not difficult to do.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite: Edius7.53, Vegas Pro v13, Power Director15, i7-950, LG 3D TV DM2752
Don Landis is offline
post #7 of 8 Old 10-02-2012, 07:36 AM
Airion's Avatar
Liked: 61
I wouldn't suggest otherwise.
Here I definitely agree. However, the OP has an LED set, which in my experience has a very large brightness budget. Most likely AndreHD has room for adjustment.
Airion is offline
post #8 of 8 Old 10-02-2012, 11:14 AM
johnnyjt's Avatar
I have a Vizio E3D320VX 3DTV and a Panasonic DMP-BDT310 and I do not have any problems
with dark 3D images. I take my glasses off and the 3D image is brighter than a 2D image
South Philly
johnnyjt is offline
Reply 3D Displays
Blu Ray Movies , Samsung , 3d Hdtv
