Looking for any advice on which 3D TV I should get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-01-2012, 07:28 PM - Thread Starter
TLang520's Avatar
Noob here,
Well I've decided it's time for my crappy 42" Sanyo to go.
I've narrowed my choices down to 3 and would like advice on which one I should go with or help understanding the advantages one may have over another. Any other suggestions if there's a better option for around $800 would be a help as well. Main uses will be for watching sports, xbox 360, and blu-ray movies. Any assistance in making my decision at all would be greatly appreciated. Thanks in advanced!
http://www.lg.com/us/tvs/lg-55LM4600-led-tv
or
http://www.lg.com/us/tvs/lg-47LM6200-led-tv
or
http://store.vizio.com/led-lcd-hdtvs/m3d470kde.html
TLang520 is offline
post #2 of 5 Old 12-02-2012, 04:55 AM
lewis3845's Avatar
I would go with the LG 55" because of the size, no it doesn't have wifi apps, but do you really need that stuff. Most bluray players have all the apps anyways and are wifi. I think especially with 3d the 55" would really be better.
lewis3845 is offline
post #3 of 5 Old 12-02-2012, 08:25 AM - Thread Starter
TLang520's Avatar
Thanks for the reply, yeah I've been leaning towards the 55" just for the bigger size. That's really the only difference between the tv's is that the 47 is a smart tv and the 55 is not right? If so you're right, I don't really need any apps with xbox and a blu-ray player.
TLang520 is offline
post #4 of 5 Old 12-02-2012, 03:39 PM
TrickMcKaha's Avatar
Bigger is always better, and especially for 3D. Until you are sitting closer than the width of the screen.
TrickMcKaha is offline
post #5 of 5 Old 12-02-2012, 03:54 PM - Thread Starter
TLang520's Avatar
Yeah, so I guess the 55" will be my best bet. Before I decide on this one, does anybody know of anything better than the LG I should check out for around $8-900?
TLang520 is offline
Reply 3D Displays
Xbox 360 Console
