Sony HMZ-T1 - How to remove the gearwheel to make the lenses movement indipent? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-07-2012, 02:56 PM - Thread Starter
Thalakos's Avatar
Hi all,
I've read all the thread about that and in all the web as well. In any case I was unable to find a real step by step guide on how to remove the famous gearwheel piece that doesn't allow the indipendent movement of the lenses making the overall image never completely focused.
Do you guys have any experience? Could you write or link a sort of a guide about that?
I'm sure there is a lot of people with this problem and I'm also pretty sure that removing the wheel finally the edge blurry effect will finish.
Thanks in advance
Thalakos is offline
post #2 of 4 Old 12-18-2012, 11:11 PM
KPAH's Avatar
Is that what you are lookig for?
KPAH is offline
post #3 of 4 Old 12-19-2012, 01:12 PM
nyc3dwd60738's Avatar
Is anyone in nyc area who can dissasambe the hmz .i would pay for the service to take the weel out
nyc3dwd60738 is offline
post #4 of 4 Old 03-05-2013, 05:58 AM
jpiechocki's Avatar
jpiechocki is offline
Reply 3D Displays
