55" 1080p 3D LED-LCD HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-19-2012, 04:38 AM - Thread Starter
SE3P's Avatar
Im new to the 3d world. I have my heart set on this samsung my question; can i switch from 2d to 3d? for example if i want to watch tv or play non 3d games.
SE3P is offline
post #2 of 3 Old 12-19-2012, 05:06 AM
lewis3845's Avatar
yes you can turn the 3d off or on. If your asking does it have a converter to convert regular 2d material to 3d, some models have it some don't it depends on the display, but the converter can also be turned off or on.
lewis3845 is offline
post #3 of 3 Old 12-19-2012, 03:26 PM - Thread Starter
SE3P's Avatar
It converts but i was wondering if i can turn off 3d and you answered that. Thanks for the help. Im about to have a lot of new man cave/toys
SE3P is offline
Reply 3D Displays
