Benq W1070 144Hz Compatible DLP-LINK 3D Glasses - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #871 of 1064 Old 06-22-2014, 01:55 PM
denis80's Avatar
Originally Posted by Nommag View Post
I bought some G15-DLP glasses off ebay, they work very well. However, they are uncomfortable on my nose, anyone have a solution perhaps a link to where I can get some cheap nose pieces that fit on them or something.
They are VERY uncomfortable to me as well. You can try these
http://www.ebay.com/itm/New-5-Pairs-.../310982706824?
but you need to make some slots in glasses with dremel or something or just use glue
denis80 is offline
post #872 of 1064 Old 06-22-2014, 10:25 PM
Nommag's Avatar
I'll give them a try, seem cheap enough to risk, Cheers for the advice.
Nommag is offline
post #873 of 1064 Old 06-23-2014, 07:05 AM
vbvamsi's Avatar
I got the G15's to test. They seem to work well. These are the only glasses which my 3 year old can wear.
vbvamsi is offline
post #874 of 1064 Old 07-07-2014, 09:30 AM
chmcke01's Avatar
Quoted: 31 Post(s)
Are there any new favorites? Seems like most of the ones that are highly rated and affordable were in old posts and the glasses are no longer available.
I have the BenQ W1070 and I am thinking about getting 2 pairs of the best sub $50 glasses I can find for myself and my wife and 2-4 pairs of the best sub $30 glasses I can find for the kids and guests. Any recommendations?
chmcke01 is offline
post #875 of 1064 Old 07-07-2014, 09:35 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 125
I have the g15s and they work really well for 13 bucks.
bori is offline
post #876 of 1064 Old 07-07-2014, 11:36 AM
chmcke01's Avatar
Quoted: 31 Post(s)
G15
So you think this is worth trying?
http://www.ebay.com/itm/G15-DLP-3D-D...item5d4a9885c0
chmcke01 is offline
post #877 of 1064 Old 07-07-2014, 11:38 AM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Yes they are the absolute best for the price. Also, if looking to pay a bit more for a better pair of glasses check out the Estar America 144hz glasses on Amazon they are the best overall imo
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #878 of 1064 Old 07-07-2014, 01:59 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
Hi Guys- I just got some Estar glasses - http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I put in Avatar and set to play 3d. Then turned on the Benq to 3d on, frame pack and it looks like blurred crap. I tried all the other settings on the Benq and couldn't get a clear, good looking picture.
What could I be missing? We had two pairs of glasses going. Tried turning them on and off etc. with no luck.
pdxrealtor is offline
post #879 of 1064 Old 07-07-2014, 11:46 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Have you tried refocusing your lens? Can you try other glasses and see if the problem is still there...?
What is the model is it: ESG601. Is the 3D setting on your projector inverted?
gamermwm is offline
post #880 of 1064 Old 07-08-2014, 02:43 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 125
Why do you need to put the BenQ to 3d. It should automatically detect the 3d disc and switche it automatically. What 3d player are you using?
bori is offline
post #881 of 1064 Old 07-08-2014, 06:13 AM
chmcke01's Avatar
Quoted: 31 Post(s)
Possible film?
Not sure if this is possible and you probably already checked...but I ordered some sunglasses online a few months ago and had the same problem, it turned out there was a film on both sides of the lens to prevent it being scratched or anything during shipping. Is there maybe a film on the lenses?
chmcke01 is offline
post #882 of 1064 Old 07-08-2014, 01:41 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
I'm not sure what was going on. I topped off the glasses with a charge, updated the BD player firmware, shut everything off then on again and it worked as it should. I had to do nothing. It was all automatic.
Thanks for all the suggestions!
post #883 of 1064 Old 07-27-2014, 04:21 PM
Liked: 0
problem
hello,
i have bought a benq w1070 projector last week but I only had the time to get a pair of 3d glasses today from NCIX. these are the ones I have:
http://www.ncix.com/detail/benq-144h...94400-1537.htm
the problem is however that I cannot get them to work. After I got home I assumed that they would sell fully charged so I tried to turn them on and the LED beside the power button flashed green briefly but the glasses didn't work. so i thought that they would need to be charged and I plugged them into the ps3 and left them charging for a little longer than 2 hours. now the LED beside the usb port is red and not blinking. when I try to turn them on the LED beside the button turns green for a brief second but the 3d still doesn't work. if then I hold the button for another 3 seconds it blinks green 3 times but again nothing happens with the image. so far whatever I tried has not been working so far. Any ideas what the problem could be? Since I have 2 pairs it's hard to believe that both would be defective.
this is my setup:
projector: http://www.canadacomputers.com/produ...item_id=055286
3d glasses: http://www.ncix.com/detail/benq-144h...94400-1537.htm
screen: http://www.canadacomputers.com/produ...item_id=063919
any ideas? thanks in advance
krz94 is offline
post #884 of 1064 Old 07-29-2014, 03:41 PM
johnsmith808's Avatar
Quoted: 16 Post(s)
Liked: 40
I just got my pair of the Estar ESG601 3d glasses. Best dlp link glasses that I have tried. I own several other brands mentioned in this thread but these are superior. Here's what I've found:
1) Greatly reduced ghosting. The only time a see faint ghosting is when playing 3d games with a black screen with a small bright area on it.
2) Sync. I haven't lost sync once yet. The other glasses I would lose sync at least a few times in each movie.
3) Flicker. To me this one is huge since I play 3d games with my pc. Usually I can only play for 2 hours and my eyes get tired. With the Estar it's like I'm not even wearing 3d glasses as far as eye strain goes. One little test is turning on a cfl light bulb with the glasses on. With other glasses you can see flicker. With the Estar I can't. I watched a 2 hour 3d movie then played various 3d video games for 4 more hours and didn't get eye fatigue that I noticed.
The comfort is fine. The brightness is average. The only negative I noticed initially were reflections. Just don't have anything that reflects light behind you. If you are watching a projector you probably don't want reflective surfaces in your room anyway.
I highly recommend these glasses especially if you are a heavy 3d user.
fredxr2d2 likes this.
johnsmith808 is offline
post #885 of 1064 Old 08-01-2014, 03:03 PM
butie120's Avatar
Quoted: 220 Post(s)
Liked: 62
So just how uncomfortable are the G15 3D glasses? They seem like a nice bargain, but I don't want something that feels obtrusive. The last few posts make it seem like these are difficult to wear. Has the forum come to a consensus on these at all? Considering you can buy three of these for the price of one Estar it's certainly worth looking into.
butie120 is online now
post #886 of 1064 Old 08-01-2014, 04:12 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 125
For the price they are great. You can make the move comfortable if you are creative.
bori is offline
post #887 of 1064 Old 08-01-2014, 04:34 PM
wayne picard's Avatar
I wear them over prescription glasses and have no problem. I don't think I would watch back to back 3D movies however. It doesn't make sense to me to spend more per pair as I require 6 sets. At $50 or more per pair buying other glasses would be 30 percent or more of the cost of the projector.
wayne picard is offline
post #888 of 1064 Old 08-01-2014, 06:06 PM
butie120's Avatar
Quoted: 220 Post(s)
Liked: 62
How would one make these more comfortable? What type of creativity are you referencing?
post #889 of 1064 Old 08-05-2014, 03:33 AM
Liked: 0
Between the following the three options, which would you recommend for me?
  • Dimensional Optics A1S01323
  • True Depth Firestorm XL
  • Estar ESG601
They all seem to be reviewed favorably around here and sit at around the same price range. Out of these three, I'm just looking for glasses with the least dark lenses that cover the most of my field of view.
McSweeney is offline
post #890 of 1064 Old 08-07-2014, 11:28 AM
scoochie's Avatar
Quoted: 40 Post(s)
I'm trying to buy new 3D glasses as well. If money wasn't an issue which glasses do you guys think are the best.
I was gonna go for these:
BenQ 5J.J7L25.002 BenQ 144hz DLP Link 3D Glasses
Like McSweeney my most important criteria are: Least darkest and cover the most field of view. Also no ghosting and flicker are good to have too!
So are the BenQ 4th gen the best if price wasn't an issue?
scoochie is offline
post #891 of 1064 Old 08-20-2014, 08:52 AM
fredxr2d2's Avatar
Quoted: 163 Post(s)
Liked: 92
Hey everyone,
I wanted to give a quick update about a company that I just dealt with: XPand. While they were short on information sometimes, they did something pretty awesome for me: they made a custom firmware so that the DLP-Link glasses can operate in dual-view gaming mode. What this means for me specifically is that my gf, who can't watch 3D, can switch the glasses to either Left-eye only or Right-eye only and watch without discomfort. The glasses weren't as cheap as others have been talked about, but they're battery-powered (2032 or whatever those little guys are) and come with several nose pieces. They also block the red-flash and seem really well put-together. I think a good experience with a company deserves some recognition, so I'm putting this here and in the main BenQ W1070 thread.
Here's to good 3D!!!
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Yamaha Aventage RX-A1030, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8040HD, 2 SM65 for L/R, 2 SM55 for sides, and 2 PM1000 for rears.
fredxr2d2 is offline
post #892 of 1064 Old 08-27-2014, 11:16 AM
Liked: 1
So is the G15-DLP glasses the best option for the BenQ W1070??
thadudedk is offline
post #893 of 1064 Old 08-29-2014, 10:36 AM
ubob800's Avatar
I just bought a pair of these but I'm seriously considering returning them. The primary reason is related red flash...the pair I received seem to suppress but not completely eliminate it. In dark scenes the background always appears to be a dark wine color instead of gray/black.
I haven't tried any other glasses with the W1070 so I can't say if others do a better job controlling red flash. I think my next move will be to see if I can still hunt down a pair of the prior-gen D3 glasses since those seemed to get universal praise. I'm not interested in third-party glasses since I had a bad experience trying them with my old Epson 5010.
BTW, the W1070 makes the Epson look totally inferior when it comes to 3D!
ubob800 is offline
post #894 of 1064 Old 09-01-2014, 10:00 PM
bhazard's Avatar
Quoted: 72 Post(s)
Liked: 54
I've tried 3 kinds so far...
G15
3DTV Corp (Hi-Shock)
EStar
The Estar has much better color than the G15. It is very noticeable. I would have never known unless I a/b'ed them back and forth 10 times like I did.
I had to charge the Hi-shock, so it wasn't ready to compare, but I feel the Estar might be better.
Here is a 4th kind I'm interested in, mainly for the micro usb charging (I hate those proprietary mini chargers)
$20
http://www.********.com/home-gadgets/pp_71655.html
Are these the newest Hi-Shock model? Looks similar.
bhazard is offline
post #895 of 1064 Old 09-05-2014, 01:43 PM
ubob800's Avatar
Originally Posted by ubob800 View Post
I just bought a pair of these but I'm seriously considering returning them. The primary reason is related red flash...the pair I received seem to suppress but not completely eliminate it. In dark scenes the background always appears to be a dark wine color instead of gray/black...
Just to close the loop, I was not able to find the BenQ "D3" generation glasses being sold anywhere reputable so I went with the Estar ESG601's instead. After doing some basic side-by-side viewing against the D4's, I can say that the Estar's do a much better job of suppressing red flash by comparison.
In bright scenes the glasses are essentially identical, although it's possible that the D4 glasses might be slightly brighter. However, that marginal increase in brightness is not enough to offset their poor treatment of red flash in dark scenes.
I should mention the Estars are noticeably lighter in weight as well. At this point I'm happy enough with the Estar's that I'll be ordering a second pair and returning the D4's.
In conclusion, I have to say I found it surprising that BenQ's own glasses have been outclassed by a third-party brand...and for $20 less. I guess it pays to do a little homework sometimes!
ubob800 is offline
post #896 of 1064 Old 09-07-2014, 01:13 PM
Liked: 0
Same Problem
Originally Posted by krz94 View Post
hello,
this is my setup:
projector:link removed
3d glasses: link removed
screen:
I did the exact same thing with my D4. One of the two glasses that I charged, I cannot get it to blink unless I connect it to the cable and with the other one the red light is not going off and the green light blinks if I click the button.
Were you able to switch the red light off? I would be grateful if u could tell me what to do.
KAran Aggarwal is offline
post #897 of 1064 Old 09-16-2014, 10:43 PM
So in europe i managed to find a pair of the ESG601 for about 100$. I think that's a bit steep, and i would also need more than a couple, for guests etc.. but i would like the best quality picture, and won't mind paying the premium for it. My question is, are there any glasses "indigenous" to Europe which has a quality comparable to the ESG601? Or maybe just the best DLP link glasses in general that one can buy from Europe?
thanks
Sean Bugeja is offline
post #898 of 1064 Old 09-22-2014, 05:22 AM
Marco T's Avatar
How well do the Estar glasses fit over prescription glasses? Anyone using them with prescription glasses underneath?
I thought the G15 were pretty good in that regard.
Marco T is offline
post #899 of 1064 Old 09-24-2014, 12:46 PM
Liked: 0
Just noticed that Ebuyer.com are now selling the BenQ W1070 for £438 with 2 yr warranty and free shipping. For anyone still looking for a home theatre projector this is an exceptional price but probably clearance of existing limited stock.
bettst is offline
post #900 of 1064 Old 09-24-2014, 12:49 PM
Liked: 0
Also, Maplins.com are selling the BenQ D4 glasses for £49.99 with free delivery which is a lot less than other sources commonly £70-£80.
bettst is offline
Reply 3D Displays
Benq W1070 1080p 3d Projector
