Benq W1070 144Hz Compatible DLP-LINK 3D Glasses - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1051 of 1069 Old 07-29-2016, 04:05 PM
CherylJosie's Avatar
Quoted: 680 Post(s)
Liked: 271
I have never used any 3d glasses with my ht1075.
I am sitting about 6-7' from a 100" screen and am concerned about the 'battery box' i.e. the dead space between left and right frames. I can barely see the whole width of the screen with both eyes due to my nose getting in the way even without glasses.
(by the way sitting close like that is just awesome for the immersion effect with neo:x 11.1 heighth/width surround sound expansion, though the extra eye movement also makes the rainbows more noticeable)
I am also concerned about the comfort and weight, plus my glancing over the thread shows that there are considerations on image quality too.
Price is also a factor although for a benq not expecting any of the options to be extremely pricey.
Does anyone have a summary chart with the currently available options listed and their strengths/weaknesses described? I am completely new to 3D and sort of lost here, but I would like to watch Avatar and Edge of Tomorrow in 3D since the projector is capable. thx
CherylJosie is offline
post #1052 of 1069 Old 08-07-2016, 03:34 AM
Liked: 0
NOT COMPATIBLE?
I just bought Ultra Clear HD DLP Link Projector 3D glasses. They seem not to be compatible. The images do not line-up. I have tried "side-by-side," "Top-Bottom," and "Frame Packing." All look extremely wrong. Is it the glasses? I am using BenQ 1075 and the Blue Ray player on XBox One.
dmark10 is offline
post #1053 of 1069 Old 08-07-2016, 04:06 AM
Liked: 0
NOT COMPATIBLE?
I tried just purchased Ultra-Clear HD DLP LINK Projector 3D Glasses for my BenQ HT 1075 and XBox One Blue Ray player. The images look very wrong - they don't line up. Tried all 3D settings on BenQ. Am I doing something wrong or are glasses just not compatible? Promotions for glasses say they work with BenQ???
dmark10 is offline
post #1054 of 1069 Old 08-08-2016, 01:26 AM
Arex's Avatar
I got burned on three pairs of SainSonic CX-30 glasses that each died because they sat around unused for too long, resulting in their batteries no longer being able to accept a charge after less than 6 hours of total use. In light of that terrible experience, can anyone recommend some glasses that WON'T die premature deaths through non-use?
Since I'll be lucky if I watch a 3D movie even twice a year, I really don't want to have to recharge the glasses on a schedule just to make sure the battery and glasses don't become unusable. (I understand if they lose their charge after 6 months of non-use, but as long as they can still be charged after 6 months of non-use, that's all that matters to me.)
Arex is offline
post #1055 of 1069 Old 08-08-2016, 04:08 PM
3DBob's Avatar
Quoted: 357 Post(s)
Liked: 113
Originally Posted by dmark10 View Post
NOT COMPATIBLE?
When you say "Don't line up." What do you mean, the images are out of alignment vertically? If the images are aligned vertically, but now horizontally, the most likely you have the left and right eye switched. Go into your menu and see if you can swap the Left and Right eye. Also, you will need glasses that handle 144hz. If you have older glasses from the past, they might not work. Ultra-Clears should work fine. Make sure you set the type of 3D to dlplink as well. If your images are truly out of alignment vertically then you have a bad projector. Can you take a photo of your screen and post it? Put your 3D image on pause if you have a bluray, and take a phone pic. That should work. That might help. It should show a double image. I just want to see what you mean by out of alignment.
3DBob is online now
post #1056 of 1069 Old 09-26-2016, 07:37 PM
dgwow's Avatar
Hi guys,
I'm buying some 3d glasses for the Benq HT2050. I looked up the estar's as they seem to get the best reviews here but they do not seem to be available anymore (I live in Canada so that makes things worse).
Out of the other available options what would you recommend?
-Firestorm XL, LT 2.0
-Ultra Clear HD
-Benq GDG5
-Gonbes G05
(Haven't seen much comparing the Ultra clear's and Gonbes/other cheap ebay brands to the other, more expensive brands)
dgwow is offline
post #1057 of 1069 Old 09-26-2016, 08:51 PM
StephenRC's Avatar
Quoted: 23 Post(s)
If you wear glasses, these can clip on: http://www.ebay.com/itm/Kolsol-G08-D...-/162072563383
They do work nicely.
StephenRC is offline
post #1058 of 1069 Old 09-28-2016, 02:27 PM
DaleNixon's Avatar
Quoted: 57 Post(s)
Liked: 6
Originally Posted by rahulp001 View Post
Thanks. Just ordered the Ultra clear HD. Will see how they turn out.
To me, now, the Ultra Clear HD's rank above the Estars. The main difference is with the Estars I am seeing more beneath the glasses (than with the Ultra Clears) letting more light through and making me less immersed in the 3D. Maybe, though, it's how they sit on my face and others won't experience the same thing.
DaleNixon is offline
post #1059 of 1069 Old 09-28-2016, 08:32 PM
dgwow's Avatar
Thanks! Bought a pair of the G05 and the Ultra Clear's, I will give feedback on them when they arrive
dgwow is offline
post #1060 of 1069 Old 11-02-2016, 09:58 AM
Liked: 0
Have they arrived? I have the G05's and I'm eager to know how the UC's compare.
Benq W1070+ // 130" DIY screen // Pioneer VSX-AX2AV (7.1) // Infinity Beta 50/C360/ES250/SW-12 & Mission 737 // Samsung BD-J7500 // PS3
kutzon is offline
post #1061 of 1069 Old 11-02-2016, 03:03 PM
Liked: 0
Originally Posted by inefekt View Post
Bought pair of G15 glasses off eBay. They're considerably lighter than the Estar glasses. Apart from taking a little longer to synch the differences are negligible, pretty impressed.
"inefekt", don't know if you frequent the forums these days, but if you're still around, could you please clarify - do you think the G15s (which I have) are just as good picture-wise than the Estars?
kutzon is offline
post #1062 of 1069 Old 11-24-2016, 11:10 AM
dgwow's Avatar
The G05's just arrived (took two months LOL) so I'll test them out later and let you know!
dgwow is offline
post #1063 of 1069 Old 11-26-2016, 11:01 PM
dgwow's Avatar
OK so I compared the two and basically the Ultra-Clears are superior.
The only noticeable difference between the two for me was the clarity. It felt like the G05 gave the picture a red/brownish tint, whereas the Ultra Clears did not have any tint to them (or perhaps they use a different tint) and made the picture appear clearer.
In terms of form factor they are both equally comfy on the eyes.
I would definitely get the Ultra Clears over the G05's (although not worth replacing as they are both suitable)
dgwow is offline
post #1064 of 1069 Old 12-13-2016, 08:33 AM
Liked: 0
has anyone tried the Benq GDG5's? Looks like there's a version 2 of these glasses available on benq's website. I recently purchased the ultra clear and they constantly lose sync with any 3d blu ray I watch on my ht3050. I've tried putting clear tape over the sensor along with other suggested fixes but nothing seems to be working. The only thing that works is lowering the brightness by 50% but then it's unwatchable. Looking for suggestions for other glasses to try that don't lose sync.
Sialyn is offline
post #1065 of 1069 Old 01-25-2017, 09:13 AM
shatheid's Avatar
Anyone able to find the DP-Link Estar's anywhere? I've been waiting awhile and haven't seen them come back in stock. Also, can't find them on ebay.
shatheid is offline
post #1066 of 1069 Old 01-25-2017, 11:57 AM
tomtastic's Avatar
Quoted: 702 Post(s)
Liked: 225
On Amazon but they jacked the price up.
https://www.amazon.com/EStar-America...25A2CF5CRYWFX1
Glad I bought 6 pair when I did. I'll probably go with something else if I need to replace. I've never had any problems with them though.
This line intentionally left blank.
tomtastic is online now
post #1067 of 1069 Old 01-25-2017, 01:30 PM
StephenRC's Avatar
Quoted: 23 Post(s)
Those are not DP-Link glasses.
post #1068 of 1069 Old 01-25-2017, 01:49 PM
tomtastic's Avatar
Quoted: 702 Post(s)
Liked: 225
Ok, sorry. I bought the DLP link ones, they looked the same, maybe that's why they're more expensive? The seller that I bought on Amazon before indicates out of stock.
EStar America ESG601 DLP® Link, website points to Amazon too but out of stock.
I looked about a year ago and they were out of stock so they've been off Amazon for awhile then. I must have seen those RF ones then too.
I was going to just order True Depth, they're 2 or 40.00
post #1069 of 1069 Old 02-01-2017, 08:48 AM
shatheid's Avatar
Let me know how you like those. I picked up a pair of the Ultra Clears, and am honestly pretty happy with them. I still need to buy another pair of glasses though, and wouldn't mind trying the True Depths.
shatheid is offline
Reply 3D Displays
Benq W1070 1080p 3d Projector
