Benq W1070 144Hz Compatible DLP-LINK 3D Glasses - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #1081 of 1081 Old 07-28-2017, 07:03 AM
mooseehead's Avatar
Quoted: 107 Post(s)
Originally Posted by MrGrimble View Post
Hi Guys,
For some time now, I have a couple of SainSonic 3D glasses for my Benq W1070. they are making the picture dimmer, but as I understood that the main problem with 3D projection.
Is there any reason to buy an original benq pair over the other no original brands?
Is there a certain benq model that doesn't make the picture dimmer, that's worth the upgrade?
I'm using the monoprice glasses. Only used them a couple times bit they work fine for me. Only problem is they are battery not rechargeable.
Sent from my SM-G930V using Tapatalk
mooseehead is offline
Reply 3D Displays
Benq W1070 1080p 3d Projector
