LG 42LM3400 - Is it possible to turn off TruMotion? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2013, 11:07 PM - Thread Starter
Erik Tande's Avatar
I can't find a setting for it anywhere. There is definitely some sort of smoothing operation going on though, everything looks very video-ish.
Thanks in advance!
-Erik
(keywords: LG 42" 3D TV, soap opera effect, video, smoothing, motion, trumotion, true motion, framerate, interpolate, frame rate)
Erik Tande is offline
post #2 of 4 Old 01-22-2013, 01:59 AM
CajunMojo's Avatar
I have a different model LG, but it should be there under picture in settings. Sorry I can't be more specific, not at home at the moment. Keep looking.wink.gif
CajunMojo is offline
post #3 of 4 Old 01-22-2013, 08:58 AM
Navigationroad's Avatar
Thanks in advance!
-Erik
I believe the LM3400 is similar to my LM5800 series TV in that the Trumotion feature, if it exists at all, is not user accessible and cannot be turned off. You might be interested in reading some off this thread in which the Trumotion feature, or lack thereof is discussed:
http://www.avsforum.com/t/1408659/lg-trumotion-missing-specific-to-42lm-47lm-55lm-series-excludes-lm7600-and-newer
Navigationroad is offline
post #4 of 4 Old 02-03-2013, 08:42 PM
ChrisTracker's Avatar
Will tridef DDD support this TV in playing PC 3D games?
ChrisTracker is offline
Reply 3D Displays
Lg 47lm5800 47 1080p 120hz Edge Lit Led Lcd Cinema 3d Hd Tv
