vt50 componet xbox 360 question?? (more to come too) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2013, 03:49 PM - Thread Starter
DerekinMerrick's Avatar
So I just set this tv up and my xbox is component. When I set it up its just a scrambled mess of black and white. Why is this? And what can I do to fix it?
DerekinMerrick is offline
post #2 of 2 Old 02-01-2013, 08:56 AM
traskii's Avatar
I'm going through the same thing. Try this:
1) flip the switch on the back of the 360 from HD to TV (I think that's it). It will make it 480i
Does that work? If so.... change the resolution to 1080i and make sure it works.
2) Do you have the red cables connected properly? One is for audio, one is for video, and they aren't clearly labeled.
My solution was to just use my receiver's HDMI output, and ignore the component, but I'm seeing the same thing.
This should probably be in the XBox area.
traskii is offline
Reply 3D Displays
Xbox 360 Console
