55LM7600 3D Display showing large amounts of "Ghosting" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2013, 01:59 AM - Thread Starter
Passive3DFTW's Avatar
Hi folks,
I recently bought a 55lm7600 LG LCD/LED Smart TV, and have been very happy with it. That is, until I tried watching a 3D movie on it. The 3d image displayed shows a large amount of crosstalk or ghosting. I have a lm6410 tv aswell, and it shows no where near as much ghosting as the 55lm7600.
My question is: does this have something to do with LG's most recent update? Does anyone else have ghosting problems on their 55lm7600 tv, and can anyone recommend any fixes for this? I've played with the 3d settings, but still can't get rid of it.
Thanks in advance,
Passive3DFTW is offline
post #2 of 3 Old 04-03-2013, 06:37 PM
Adamd's Avatar
Quoted: 594 Post(s)
Liked: 375
Is your head level with the center of screen? The way passive works if your tv is higher up above or below eye level you will get crosstalk.
Adamd is online now
post #3 of 3 Old 04-10-2013, 09:43 AM
Natrix1973's Avatar
Quoted: 27 Post(s)
Liked: 30
I have a LG that 3d looked really crappy and unimpressive out of the box. In the Avengers, the scene with Black Widow pointing her gun at the camera in the shack looked terrible. The gun was not popping out and it was rendered like a double image and way out of focus. I changed the picture mode from the default in 3d mode to Cinema and the 3d was perfect after that. It sucks that it has to be changed every time I go into a 3d mode but it works for me.
Give that a shot and see if it improves.
Natrix1973 is offline
Reply 3D Displays
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv
