HELP, LG 55LW5300 Image Issues. - AVS Forum | Home Theater Discussions And Reviews
Old 04-25-2013, 06:00 PM - Thread Starter
mavicious's Avatar
i just recently bought a lg 55lw5300 from craigslist, stupid me didnt check all of the settings before buying and just looked at it they way he had it set up already.
so i get the tv home and the image is too bright for my taste, like a normal person would do i go into picture settings and move it to the other preset's just to see how they look, thats when i noticed a big problem. im not sure how i should describe this or what its called but from my gaming days it looks like crazy bad gamma or a inverted image. so did i just buy a broken tv or is there some magical way to fix this?
i have updated the firmware to 5.00.01 that did nothing though. here are some pictures to show you what im talking about
is the video processing unit bad? i dont think its the screen itself though i could be wrong
mavicious is offline
Old 04-25-2013, 11:44 PM - Thread Starter
mavicious's Avatar
after reading through other forums and finally finding one similar problem ive ordered a TCon Board and lets hope that solves this problem as well.
Old 05-02-2013, 08:19 PM - Thread Starter
mavicious's Avatar
Well changed the t-con to no avail. And seems no one here has any ideas either
