Strange issue with 3D on my new Samsung FH6030 and Sony BDP-S590. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-27-2013, 05:37 PM - Thread Starter
SeanWPayton's Avatar
Hey guys,
I had some issues originally getting the 3D to work on the TV, but I finally got it to play 3D blu rays. The problem now is that the 3D picture is not entirely in 3D (a lot if it is blurry like viewing withouy glasses). It seems like the close stuff is all in 3D whereas the other stuff in the background stays blurry.
I am not sure if the glasses I am using are at fault, they are simply some Real-D 3D glasses I got from cinemark the other day (they work on my brothers LG so I figured they would work on this).
Has anyone ever experienced this? Its difficult to explain, even in the menu of the blu ray the text is sort of side-by-side, looks the same with and without the glasses.
My blu ray is a Sony BDP-S590
http://www.amazon.com/Sony-BDP-S590-Blu-ray-Player-Wi-Fi/dp/B006U1YUZE/ref=sr_1_1_ha?ie=UTF8&qid=1369697692&sr=8-1&keywords=sony+bdp-s590
and the TV is this:
http://www.samsung.com/us/video/tvs/UN55FH6030FXZA
SeanWPayton is offline
post #2 of 5 Old 05-27-2013, 06:00 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
You might want to post this to the forum that is appropriate for your tv. Other owners may have some suggestions for you.
Otto Pylot is offline
post #3 of 5 Old 05-28-2013, 09:03 AM
phage80's Avatar
The problem is the FH6030 uses active 3D glasses, the glasses for Real D 3D are passive so do not work.
Samsung sells some cheap active glasses $20 a piece.
phage80 is offline
post #4 of 5 Old 05-28-2013, 11:29 AM
holl_ands's Avatar
Quoted: 437 Post(s)
Liked: 180
And not all Active 3DTV Glasses are the same....in addition to using different transmission systems (some Universal Active 3D Glasses support multiple systems), they are color-matched to each manufacturer's set. So if you decided to buy Active Glasses from other than the set's manufacturer, you might want to be sure that they are not only compatible but also INTENDED for your 3DTV. Hence, there is no such thing as completely compatible Universal Glasses for BOTH Samsung and Panasonic....the color balance is a bit different.....if you care about such things....
holl_ands is offline
post #5 of 5 Old 06-11-2013, 06:50 PM
slayerdave's Avatar
the un55fh6030fxza is an active 3d hdtv. you will need the active (battery powered) glasses. they are models
SSG 5100GB for non rechargeable
SSG 3570R for rechargeable
slayerdave is offline
Reply 3D Displays
Sony Bdp S590 3d Blu Ray Player , Sony Bdp S590 3d Blu Ray Disc Player
