Samsung UN60ES7100 or UN60F7100? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-31-2013, 07:11 PM - Thread Starter
tonytyme23's Avatar
I am looking to purchase a 60 inch 3d display and I would like to know the differences in these two displays? I believe the ES7100 is last years model, is it worth the extra money for the 2013 model? Is there a difference in bezel size? Any input would be great!
tonytyme23 is offline
post #2 of 2 Old 06-07-2013, 02:34 PM
mrkyymrk's Avatar
F7100 is way better..
3D is better as well.. you can adjust the light in 3D..
answer is F7100
mrkyymrk is offline
Reply 3D Displays
Samsung Un60es7100 Led Hdtv , Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv
