BenQ w710st 3D help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-17-2013, 11:35 AM - Thread Starter
dbldare's Avatar
Hey all. I'm normally hanging out over in the DIY section but need the help for a friend and his projector, and I knew this was the area. He has a BenQ710st and a Sony dvd bdp-s5100 running directly to it via HDMI 1.4. He is not getting any 3D image at all. In fact, the 3D settings on the projector are all greyed out. I think it's because the projector needs to be run off a computer via Nvidia set up, correct? Or is it something else?
Any help would be very much appreciated.
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #2 of 4 Old 08-17-2013, 04:54 PM
lurkor's Avatar
Quoted: 29 Post(s)
Liked: 34
This is what I run on my 2nd hdmi input of the 710st and it works great, although I've never tested it with that particular blu ray player. Unfortunately the price on the adapter has jumped considerably, and they are getting more difficult to find.
http://www.projectorcentral.com/optoma_3D-XL_review.htm
I hope this helps.
lurkor is offline
post #3 of 4 Old 08-17-2013, 09:53 PM - Thread Starter
dbldare's Avatar
lurkor - Thanks for the reply.
So the 2nd HDMI input makes a difference? Weird.
dbl
dbldare is offline
post #4 of 4 Old 08-17-2013, 11:31 PM
lurkor's Avatar
Quoted: 29 Post(s)
Liked: 34
The 3d-xl adapter works equally well on both hdmi inputs, but I have a PC feeding the first at 120hz with an AMD 7950 on that setup, and dlp link glasses for both inputs. Works like a charm.
lurkor is offline
Reply 3D Displays
Benq W710st Short Throw Hd Dlp Projector
