Which passive 3D: Sony W8 or LG? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-21-2013, 08:42 AM - Thread Starter
Sherongan's Avatar
HI
I really need your help guys.
I planing to buy a new TV soon
1) I want a very good 3D performance, with high depth, color and sharpness.
2) I want HD 1080p resolution at a high level.
I wanted to buy the LM760T of LG, because of the strong 3D and 2D performance, but then I found out, that there are a bad backlight bleeding on this TV...
Now I thinking about the KDL W805A of Sony.
this TV has very low input lag, nice 2d display and cute 3D performance.
I tested both TV'S only on the 3D, and I have to say that in my opinion, the LG had better 3D and depth compared to the W8...
Which TV should I buy?
maybe one of the new LA 2013 models of LG?...
What is your opinion?...
Sherongan is offline
post #2 of 2 Old 11-09-2013, 05:36 PM
LeeC22's Avatar
I have the Sony KDL-47W805A and would find it hard to recommend it to anyone. Panel uniformity is poor, 3D is full of crosstalk... or at least mine is. I never even thought to test the 3D in the shop, because of how everyone raved over passive 3D. I watched a passive LG set once, and it was much better than this, so thought it was a safe bet, considering the price.
Like I say though, mine might just be really faulty... or based on the quality of my Xperia Z tablet, it might just be typical of Sony and the mediocre quality of their current range of products.
LeeC22 is offline
Reply 3D Displays
