Need help picking projector screen for budget theater project - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2013, 08:56 AM - Thread Starter
maxvalocity's Avatar
Ok so I am building a theater room in my basement and need help picking a screen for it. My projector that I have chosen is the benQ 1080st. I have about 75" that's from the front of the projector.
Screens under consideration:
1:) Elite Screens ELECTRIC125H-A1080P2 Spectrum Projection Screen acoustic pro
2:) Elite Screens ELECTRIC125H Electric Projection Screen max white
3:) Elitech 120" Electric Screen 16:9 HDTV Format High Contrast Grey
That's what I have so far these are all on amazon, I will take suggestion on these ones and others.
Budget is $500 with shipping
maxvalocity is offline
post #2 of 3 Old 09-09-2013, 05:16 PM
rekbones's Avatar
Quoted: 479 Post(s)
Liked: 248
Why not a fixed frame screen if its a dedicated theater room. The 3 screens you show are for three different room setups.
1. Acoustic screen if you are placing the speakers behind the screen.
2. Cine white for a dark colored light controlled room.
3. Gray screen for room lighting issues or light colored walls for better contrast
most retractable screen will develop wrinkles if they aren't tab tensioned.
you might get a better response if you post this in the screen section
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 09-09-2013, 08:38 PM - Thread Starter
Well it is a light controlled room and I will be setting up a 70" sharp behind it with the floor standing speakers behind it. What do you recommend for tension screens?
Reply 3D Displays
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
