Optoma 3d ready dlp projector - AVS Forum | Home Theater Discussions And Reviews
Old 09-09-2013, 03:23 PM - Thread Starter
Ramy Khalil's Avatar
I have an optoma HD33
in order to be able to watch 3d content.. be it blu rays, ps3 games tv channels etc..
do i need an emitter and glasses
or
3d-xl adapter
or
both?
Ramy Khalil is offline
Old 09-09-2013, 06:01 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
If you bought it new or manufacture refurbed it should have come with an RF emitter. All you need are either DLP link glasses or if you have the emitter then Optoma rf glasses will also work. Also any compatible IR emitter will work with matching glasses. I believe there are also compatible Bluetooth emitters for Bluetooth glasses. Your cheapest option is any DLP link glasses no emitter needed
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Old 09-09-2013, 06:10 PM - Thread Starter
sorry man i am confused by your answer...
"If you bought it new or manufacture refurbed it should have come with an RF emitter."
i bought it new, and it didnt come with emitter nor glasses..
"All you need are either DLP link glasses or if you have the emitter then Optoma rf glasses will also work."
whats the difference?
"I believe there are also compatible Bluetooth emitters for Bluetooth glasses."
are these better then non bluetooth glasses and emitter? why?
i think the blue tooth emitter has to keed getting changed coz the are not directly connected to the projector.. but why would it be a better option..
Old 09-09-2013, 06:24 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
When I bought mine it came with the RF emitter, maybe they don't include it any more. There is a red flash that the DLP link glasses sync to that some believe causes a contrast loss so some claim the RF is a better option but a lot more expensive. All the glasses for this projector ether need to be recharged or the batteries replaced as they are active. Just buy some DLP link glasses off ebay for about $20 and try them out
rekbones is offline
Old 09-09-2013, 06:31 PM - Thread Starter
so i have to buy the emitter and some glasses.. what is the 3d-xl adapter? is it required?
Old 09-09-2013, 06:34 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
No you do not need an emitter for DLP link glasses, the DLP setting in the projector creates a red sync flash on the screen that the glasses sync to. No adapter of any kind is needed.
rekbones is offline
Old 09-26-2013, 09:48 AM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
stuart628 is offline
Optoma Hd33 3d Ready Dlp Projector , Optoma Hd33 1080p 3d Projector
