Looking for ir 3d glasses compatible with panasonic 50st60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-28-2013, 10:14 AM - Thread Starter
kevgees's Avatar
Which other ir 3d glasses will work on the panasonic 50st60?
kevgees is offline
post #2 of 2 Old 01-09-2014, 03:11 PM
richierich93's Avatar
Only universal RF (Radio Frequency) glasses will work with the Panasonic ST60, not IR (Infrared). So, try any active Samsung 3D glasses. There are $20 Samsung glasses that will work, however, they're battery operated and do not give you as nice of a 3D experience as the $50 Samsung rechargeable ones can. However, since Panasonic and Samsung have all met the Universal Active 3D standard. Supposedly, any active 3D glasses should be able to pair up, as long as they are RF from what I understand.
richierich93 is offline
Reply 3D Displays
Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv
