3D glasses and how they fit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-10-2014, 03:33 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
I just got these 3D glasses, Estar America ESG601 DLP Link 3D.
They seem to work great, but they don't really hug my face. I can see outside the glasses if I look up or down.
Is this typical of all 3D glasses?
pdxrealtor is offline
post #2 of 4 Old 07-11-2014, 01:43 AM
MLXXX's Avatar
Quoted: 195 Post(s)
Liked: 94
It is typical of 3D glasses. (You use the glasses to watch the display screen, which is directly in front of you.) And it is typical of prescription glasses, though with prescription glasses in everyday life you may find you occasionally actually need to cast your eyes all the way up or all the way down and you will then momentarily lose the correction provided by the prescription glasses.
I've noticed that cheaper active 3D glasses are sometimes a little smaller in lens area, presumably as a cost savings measure.
People who need to wear prescription glasses for distance simply put on 3D glassses as they would sunglasses, i.e. over their prescription glasses. This is not usually a problem.
MLXXX is offline
post #3 of 4 Old 07-11-2014, 02:39 AM
Liked: 0
Hi, as i know. their have different size, some are very big but some are not. also have small size for young children. you can choose the suitable one for yourself...
ID:	156266   Click image for larger version
ID:	156274   Click image for larger version
ID:	156282   Click image for larger version
Ice Age is offline
post #4 of 4 Old 07-11-2014, 12:21 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
Reply 3D Displays
