3d blu ray vs pc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-05-2014, 02:27 PM - Thread Starter
Liked: 0
3d blu ray vs pc
Hi, I wanted to ask you folks about the difference in playing 3d sbs movies to my lg 3d tv from my computer or playing them from blu ray 3d.
If the sbs movie played from the computer is the same size and quality tan the bluray, does it look different?
francisco hernandez proto is offline
post #2 of 5 Old 09-26-2014, 08:01 PM
tomtastic's Avatar
Quoted: 259 Post(s)
Liked: 92
Just saw this is still unanswered, so...if you have a passive TV, the glasses will block out the extra lines, so you're only getting 540p per eye, so in a since SbS will be roughly the same quality.
This line intentionally left blank.
tomtastic is online now
post #3 of 5 Old 09-26-2014, 09:06 PM
Jedi2016's Avatar
Quoted: 35 Post(s)
Liked: 54
Regardless of the pixel argument, SBS movies are, by definition, lower resolution and suffer more compression than the original Blu-ray, which can be devastating to the 3D effect if it's not done correctly. IMO, there's no substitute for the original Blu-ray.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
post #4 of 5 Old 10-01-2014, 10:17 AM
Liked: 0
I wondered the same thing, thank you!
Sharken Beard is offline
post #5 of 5 Old 10-06-2014, 08:30 PM
IanD's Avatar
Quoted: 26 Post(s)
Liked: 26
SBS 3D movies are simply 2D frames containing both eye views. They are usually converted to the required individual eye views by the display device, if it is told they are SBS.
Consequently, sending these SBS 2D frames to a 3D display via a PC or Bluray player as 2D frames will give exactly the same result.
If you are talking about converting SBS 2D frames to proper frame packed 3D in a PC or Bluray player, then the result may vary depending on whether the device supports that functionality and how well it performs the conversion.
If you mean is there a difference between SBS 3D movies via PC and proper 3D Bluray movies, then yes the genuine 3D will be better since the SBS 3D is halved in resolution and possibly compressed even further.
IanD is offline
Reply 3D Displays
computer , quality , sbs
