Problems using BenQ MH530 with Nvidia Stereoscopic 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-18-2017, 05:31 AM - Thread Starter
Liked: 0
I have a PC with a Geforce GTX 550 TI hooked up to a BenQ MH530 3D projector and PowerDVD 13 with a high speed HDMI cable. When I setup Stereoscopic 3D in the Nvidia Control Panel it tests fine. I have set the resolution set to 1080p 1920x1080 24HZ the same as the native resolution of the projector.
My problem for example, when I launch a .mkv SBS or OU movie using PowerDVD, I get a message in red saying "Current mode 1920x1080 @60Hz is not HDMI 3D compatable." Nvidia Control Panel is set correctly to HD 3D 1920x1080 @24Hz so I don't understand. I set PowerDVD to SIDE by SIDE or OVER UNDER in the PowerDVD 3D settings and I still don't get a 3D image just a side by side or over under.
I have the same setup with another computer using a Geforce GTX 550 TI and ACER H5380BD 3D 720p projector 1280x720 and everything works perfectly. PowerDVD auto-detects if the .mkv is SBS or OU, it works like a charm so this other projector is driving me nuts.
Any help would be appreciated.
Teletranone is offline
post #2 of 2 Old 04-18-2017, 09:27 PM
rekbones's Avatar
Quoted: 497 Post(s)
Liked: 253
When playing a SBS/OU 3D .MKV file you need to disable 3D in the PC and powerDVD, just send the SBS/OU image to the projector manualy setting the projector to 3D SBS/OU to play the file. Let the projector merge the images not the PC or PowerDVD.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Reply 3D Displays
