DirecTV To Deliver 3DTV With Harmonic Encoders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-08-2010, 09:41 AM - Thread Starter
Lee Stewart's Avatar
Liked: 51
DirecTV will use its existing HD encoders from Harmonic to launch three dedicated 3DTV channels in June, in a "frame-compatible" format that takes up the same amount of space as a regular HD stream.
"Harmonic is a trusted solution provider for DirecTV, with outstanding solutions including the Electra encoders which not only enable us to efficiently deliver excellent quality HD, but also can flexibly support new applications such as 3D," DirecTV chief technology officer Romulo Pontual said in a statement.
http://www.multichannel.com/article/...c_Encoders.php
Lee Stewart is offline
Reply 3D Source Components
