Purchase Quandry - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2010, 03:24 PM - Thread Starter
John DR's Avatar
I notice that the upper scale players decode all sorts of formats. Question: if you have an AV receiver that also has quality decoders, is this an unnecessary duplication?
I will be buying a new AV receiver too. If I get, for example, a Pioneer SC-35, why get a blu ray player that also does the same decoding. As a novice, it seems you only need a player that faithfully sends the blu ray content to the receiver, so your receiver can do the work you bought it to do.
Is this correct, or am I missing something basic?
John
John DR is offline
post #2 of 3 Old 10-15-2010, 11:03 AM
Justin-Dawson's Avatar
Correct. I find that having the Blu-ray player decode audio and send it to the receiver in Linear PCM results in the receiver having less control with adjusting desired audio effects as well. Buy a decent blu-ray player that can send audio through bitstream and have your receiver do the work.
Justin-Dawson is offline
post #3 of 3 Old 10-15-2010, 11:08 AM
mgkdragn's Avatar
Quoted: 1764 Post(s)
Liked: 2045
Unless you have a PS3 Phat ..
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
Reply 3D Source Components
