Best HDMI cables for 3D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 11-15-2010, 03:09 AM - Thread Starter
axlerod7's Avatar
I am putting together a 3D package and don't know what to do for cables. The plan so far is Panasonic TC58VT25, Pioneer VSK-1020-K, and Panasonic DMP-BDT350. I want to take advantage of the video and audio available in these components. It looks like Monster cables use optical for the audio and now I am confused looking at too many websites. Thank you in advance for your help.
axlerod7 is offline
post #2 of 21 Old 11-15-2010, 04:43 AM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2393
Future proof. Get high speed HDMI cables with Ethernet. Don't buy exorbitantly priced Monster cables. Ripoff alert.
Get your cables here: http://www.monoprice.com/products/su...02&cp_id=10250
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
post #3 of 21 Old 11-15-2010, 09:17 AM
walford's Avatar
You don't need or want High Speed cables with Ethernet since none of the HDMI 1.4a 3D formats use Ethernet to send any part of their signal from your 3D source which most likely does not even support ethernet anyway.
Standard HDMI high speed cables are all that are required.
walford is offline
post #4 of 21 Old 11-15-2010, 03:03 PM
alk3997's Avatar
Liked: 92
Author deleted comment
alk3997 is offline
post #5 of 21 Old 11-15-2010, 05:03 PM
dan webster's Avatar
Quoted: 141 Post(s)
Liked: 99
High speed cables only go up tp 25 ft as far as i can find. My problem is that i need 30 ft. Any ideas?
Dolby Atmos 7.2.4 Marantz AV8002a processor Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 bluray player Jvc 4910 projector Vivitek 1186 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 5 L&R &super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is online now
post #6 of 21 Old 11-15-2010, 05:22 PM
alk3997's Avatar
Liked: 92
alk3997 is offline
post #7 of 21 Old 11-15-2010, 05:56 PM
Colm's Avatar
Liked: 94
Be wary of any claims of high speed cables over 25'. Ask for a copy of the certification report. BJC Series 1, arguably one of the best HDMI cables avaliable, is certified 25' max. IIRC Kurt said it would probably certify at a max of 27'. That said, some longer versions of the same cables as are certified for 25' will probably work just fine because the tests are worst case and hardly anyone is pushing the maximum bandwidth.
Colm is offline
post #8 of 21 Old 11-15-2010, 06:12 PM
Quoted: 141 Post(s)
Liked: 99
Monoprice has 25' 22 g high speed cables .i thought a could also try a 6' high speed male to female hdmi cable for a total of 31', which is enough.
post #9 of 21 Old 11-15-2010, 10:19 PM
Colm's Avatar
Liked: 94
Just so you know, a 25' high speed cable plus a 6' high speed cable does not make a 31' high speed cable.
Colm is offline
post #10 of 21 Old 11-16-2010, 09:35 AM
walford's Avatar
The only sure way to use two lenghts of High Speed cable to go over 25" is to put an HDMI signal ampifier between them.
walford is offline
post #11 of 21 Old 11-16-2010, 11:02 AM
sleepers's Avatar
I'm using the following:
40' 22 guage in wall regular speed with no problems. I have it connected between a panasonic 3d tv & panasonic 3d DVD player. We watched 3d Ice Age last night with no problems.
Be warned it is a huge cable.
sleepers is offline
post #12 of 21 Old 11-16-2010, 10:09 PM
Quoted: 141 Post(s)
Liked: 99
Thanks i was not aware of that. I may just try using my current 35" cable when my new jvc pj arrives and hope for the best. If it will not work for 3d i will worry about it then.
post #13 of 21 Old 11-17-2010, 06:42 PM
alk3997's Avatar
Liked: 92
alk3997 is offline
post #14 of 21 Old 11-17-2010, 07:12 PM
Quoted: 141 Post(s)
Liked: 99
What jvc are you getting? I preordered the 40 here ar avs. I hope my current cable works. I still have to buy another cable because i am keeping my panasonic 3000 pj primarily for my sons xbox. He puts mega hours on the bulb. I cant wait til the jvs arrives, I will be taking a couple of days off from work to play.
post #15 of 21 Old 11-18-2010, 09:35 AM
alk3997's Avatar
Liked: 92
alk3997 is offline
post #16 of 21 Old 11-18-2010, 10:20 AM
walford's Avatar
Bandwidth is not the issue it is loss of signal strength or degreadation of the analog the wave forms used to trannsmit the digitlal signals.
walford is offline
post #17 of 21 Old 11-18-2010, 11:13 AM
alk3997's Avatar
Liked: 92
alk3997 is offline
post #18 of 21 Old 11-18-2010, 11:50 AM
MovieTime's Avatar
The High Speed cables from DVIGEAR.com will work at considerably long lengths. They are the FAT blue ones and they are reasonably priced for what they are. Digital Projection International uses them all the time when they are on the road doing 3D Demos with their 60K+ Titan Dual 3D projectors.
I've seen them running lengths over 50ft on those cables and they work with Bluray 3D content.
There are plenty of cables out there that will work shorter lengths, but if you need serious length I've seen these DVIGEAR cables work extremely well.
And as others have said, especially for the shorter lengths 30-40ft and under, people have had very good luck with Monoprice. You won't go wrong with BlueJeansCable either, their stuff is top notch. Monster would be throwing money away.
MovieTime is offline
post #19 of 21 Old 11-18-2010, 01:12 PM
Colm's Avatar
Liked: 94
Originally Posted by alk3997 View Post
...the (essentially) carrier-wave ...
There is no carrier.
Colm is offline
post #20 of 21 Old 11-18-2010, 08:23 PM
walford's Avatar
1080p/60 is not an ATSC standard resolution. 1080p/24, 1080p/30, and 1080i/60(1080p 30 fps) are. 3D blu-ray Double buffer packed frame content is 1080p/48 which requires more content per single buffer transmission.
walford is offline
post #21 of 21 Old 11-19-2010, 12:10 PM
alk3997's Avatar
Liked: 92
Author deleted retraction
alk3997 is offline
Reply 3D Source Components
