Sony 3D Bloggie just arrived - AVS Forum | Home Theater Discussions And Reviews
post #1 of 124 Old 04-30-2011, 08:55 AM - Thread Starter
Don Landis's Avatar
Quoted: 1222 Post(s)
Liked: 326
Just received my 3D Sony Bloggie. First off, I want to say that I bought this almost blind as I didn't actually spend much time handling one at the trade shows. I decided to get it because the TD10 I have on preorder is continuing to be backordered and delayed. Plus I did want a small camera to do 3D I could carry like a pocket cam. It came down to Bloggie or the Fuji W3 and the Fuji had many bad reports on video quality.
The 3D Bloggie came in a very small box velvet lined and at first I thought I was sent a wrist watch or piece of jewelry. All that came with it is a bunch of papers on different warranties and a small tri fold for basic instructions; a wrist strap; and USB extension cable. The bloggie had enough charge on the battery to try it oput for a few minutes.
Initial impressions:
The 3D screen is nowhere near the quality on the TD10 but closer to that of the JVC TD1. If you have a JVC TD1 then you will be familiar with the look in 3D and just that the Bloggie screen is a bit smaller is size.
Shooting 3D is quick and easy and the cameras are set up for good 3D on the glasses free screen at distances from 3ft to about 15 ft. Beyond that the Bloggie screen looked pretty flat. Closer than 3 ft. the divergent ghosts began to appear. Conclusion- 3D is best shot at 3' to 15' for impressive depth. I will try it outdoors for bigger scenery 3D later.
Playback was quick and easy to navigate through the few clips I shot.
The Bloggie came charged enough for about 15 minutes of shooting and playback. I now have it plugged into a small USB wall charger.
The Bloggie comes with it's PC application self contained in the camera so you can take it to any PC with a USB port and just plug the Bloggie in and be able to transfer your video for internet social networks upload or save to process later on.
Switching between 2D, 3D and still pictures is a one button simple to do operation. It has a LED light to aid in shooting low light levels.
More to come...
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #2 of 124 Old 04-30-2011, 12:38 PM
icerat4's Avatar
Cool Hope to get a real inside review from ya.
icerat4 is offline
post #3 of 124 Old 04-30-2011, 12:47 PM
TonyW79SFV's Avatar
I echoed the same sentiments on getting the 3D Bloggie due to delays in getting the TD10. I'm anticipating my 3D Bloggie early next week (I'm cheap, I used free shipping). I read the 3D Bloggie handbook online and what you mentioned about 3D being optimized at up to 15 feet reflected what the manuals optimized distance listed - 16 feet. From what I read, the 3D Bloggie records 3D only in 1920x1080p30 in side by side format, so any video editing program will edit it provided you edit without unsymmetrical effects or text. This is also Sony's first Bloggie with stereo audio recording. I have seen pretty good quality clips from the 2D Bloggie online and anticipate similar quality from this; although it seems that the Bloggies, like all shoot and share (Flip-type) camcorders, suffers more from CMOS jello effects than regular CMOS-based camcorders (I own an EX1, CX500V, and HC1 and see little of the jello effect on those cams).
TonyW79SFV is offline
post #4 of 124 Old 04-30-2011, 03:25 PM - Thread Starter
Don Landis's Avatar
Liked: 326
Tony- By Jello effect do you mean the video jiggles? If so I have observed that and I am playing with the clips in Vegas image stabilize and it has little to no affect on the video.
I shot about 20 different clips with a tripod and about a dozen handheld as careful as I could and the jiggle is just real bad. I shot a couple clips in 2D and it was not near as jiggling as the 3D. IMO, this issue makes the 3D Bloggie video when hand held unusable. There is a demo piece that comes embedded on the bloggie and I believe they used a tripod, jib, or dolly for each of the shots. My tripod stuff is quite usable, however. So here's my initial reaction to this first observed limitation. I have one of those real cheap 6" tripods I will have to carry. I need to go in the shop and fabricate a right angle bracket or come to think of it, I have a couple of knuckle mounts I can adapt. The Bloggie 3D has a 1/4-20 socket only on the vertical and shooting in 3D requires the camera be in horizontal or you get an error message.
When I first looked at the clips I shot, I was real disappointed in the sharpness of the image and got a bit concerned this would not mesh well with other clips mixed with the TD10 later on. Then I happened to notice I forgot to take the little plastic lens shipping protectors off. I had been shooting through those thinks taped to the lenses! Talk about ROFLMAO. Anyway with the tape removed the video was not only much brighter, but alot sharper too.
More to come...
Update- Finished the 90° elbow swivel modification to the little tripod. Adds a little bulk but still able to put in my pocket. Plus I made it so it is a quick connect and release for fast setup.
post #5 of 124 Old 04-30-2011, 03:43 PM
TonyW79SFV's Avatar
The jello effect is one artifact inherent with CMOS rolling shutter, the other is flashband. The jello effect tends to be more amplified when CMOS based cameras are subjected to vibrations, but even slight hand movements can cause it; but the effect is more of an issue with cheap CMOS cameras (Flips, Bloggies, and cell phone videos) than traditional camcorders (like Handycams or even XDCAM EX). I don't expect the Bloggie to match even the cheapest Handycam in terms of video quality, there is a reason for the price difference; nevertheless I'll enjoy my up-and-coming 3D Bloggie despite its limitations.
Don, you got me scared on the sharpness issue, good thing it was a simple lens protector!
post #6 of 124 Old 04-30-2011, 05:28 PM - Thread Starter
Don Landis's Avatar
Liked: 326
Just reviewed the first set of clips on the big screen and I am surprised how good the clips looked that had the lens covered over with the protection tape.
I am still not happy about the hand held quality on the 3D Bloggie but the stuff on the tripod looks good as I expected for natural light. The 3D effect is quite good with no ghosting or 3D cross talk.
What does surprise me is that I thought the whole idea of the Bloggie was to be a hand held camera for hip, MTV style shooters. Sorry but the technical limitations will just not take the camera moves in 3D. Tripod only, I'm afraid. Want to shoot your kid's birthday party? Better plan on setting up the Bloggie in a good spot on the tripod, turning it on and forget about it. Hand holding is a good way to waste memory and battery.
So far the image quality in 3D I'm seeing is about what I get with my cellphone camera.
I think this follows the old saying you get what you pay for. 2 $125 digital cameras.
post #7 of 124 Old 04-30-2011, 06:55 PM
icerat4's Avatar
no worrtes the big boy will be around soon,
icerat4 is offline
post #8 of 124 Old 05-01-2011, 02:01 AM - Thread Starter
Don Landis's Avatar
Liked: 326
Yes, but I'm still needing to learn the limitations of this Bloggie. I'm just disappointed in it's hand held capability.
When I get into shooting my projects, I plan to set the Bloggie up on sticks from a different angle and just roll as I shoot the key shots with the TD10. The Bloggie does have excellent 3D separation on some shots I did with foreground 5ft and distant objects between 40, 50, and 200 ft away. This with no real ghosting on the foreground. That is encouraging. It will still have a purpose, just will avoid any hand holding.
post #9 of 124 Old 05-01-2011, 11:18 AM - Thread Starter
Don Landis's Avatar
Liked: 326
OK here's my attempt at using You Tube 3D I had to renew and link my accounts as I haven't used YouTube in a couple years.
Finally got it working.
http://www.youtube.com/watch?v=MHdeB0ra5WM
The video has a variety of clips from micro tripod, to handheld, sunlight to shade, simple to busy subject around my backyard. I have not viewed this video on my Sony Projector, only on YouTube in anaglyph color mode. I also just learned about the 3D tags and I must say that info was hard to find.
So, this is my first attempt with the Bloggie shot this morning at 10:30AM clips were quickly butted together in Vegas and rendered. Then I spent an hour trying to figure out how to do this in You Tube.
post #10 of 124 Old 05-01-2011, 12:21 PM
icerat4's Avatar
Holy crap Don . Me and you have the same dog. I swear there twins OMG Funny.
icerat4 is offline
post #11 of 124 Old 05-01-2011, 12:50 PM
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
left and right was not right.
you have to use the red cyan turned over
means right eye is red left eye is cyan.
normally the standard is opposite.
W.Mayer is offline
post #12 of 124 Old 05-01-2011, 05:41 PM
Frank's Avatar
That video has noticeable vertical disparity.
Did IQ's suddenly drop sharply while I was away?
I enjoy 3D in spite of HDMI 1.4!
Full screen only 3D doesn't cut it!
Frank is offline
post #13 of 124 Old 05-01-2011, 08:02 PM - Thread Starter
Don Landis's Avatar
Liked: 326
Yes, I saw that and wondered why it came out that way. The option to check flip the left and right is in the 3D pull down menu in YouTube. So, you don't need to flip your glasses upside down. But I wonder why the output from the Bloggie rendered in Vegas to link the clips then uploaded needed to be flipped like that.
post #14 of 124 Old 05-01-2011, 08:33 PM - Thread Starter
Don Landis's Avatar
Liked: 326
Frank- Help me understand what you mean by Vertical Disparity.
I plagiarized the swap tag from your Fox with cubs video to fix mine. yt3d:swap=true
It's working properly now.
post #15 of 124 Old 05-02-2011, 11:15 PM
dwhite601's Avatar
I suspect he means objects in one view were higher than the other.
dwhite601 is offline
post #16 of 124 Old 05-03-2011, 01:19 AM
TonyW79SFV's Avatar
My Sony MHS-FS3 Bloggie 3D arrived and I had a chance to toy around with it in the evening, which meant that I didn't have sunlight to shoot the best quality footage. Adequate lighting video quality is pretty much what I expected - about or a bit better than cell phone quality for both stills and video (in this case, it was much better than my LG Ally phone). I also own a similarly sized Sony DSC-TX7 CyberShot camera that can record AVCHD and also MP4, and the quality of stills and video of the CyberShot is much better than the Bloggie (but below my CX500V Handycam). However, the 3D effect worked really well on the Bloggie, and that's pretty much the reason why I bought it (aside from waiting for the TD10). Looks as if the Bloggie is better suited for daylight shots even with the built in LED. There is a demo video included that demonstrates the 3D effects (the one with the girl blowing bubbles), but I doubt that video was shot with the Bloggie.
post #17 of 124 Old 05-03-2011, 01:45 AM - Thread Starter
Don Landis's Avatar
Liked: 326
Tony- I disagree. The sample video looks and feels exactly like a Bloggie video as it has the same level of grain in the picture and same focal length lens. It was a tripod and jib move for the indoor shot and the lighting was very flat and difuse indoors and outdoors was just a bit less sun and less color than I got in my around the pool scenes.
The real problem I have with the Bloggie is the shakiness and lack of image stabilization. I had hoped it had that feature but you need a tripod to get good 3D from the Bloggie. Otherwise, as stated earlier it jiggles.
Lighting is Key for good video. The sample shows the indoor shot with few shadows and very flat lights. I have some really good light kits here so someday, I will set up a three point light configuration and show you what can be done with good indoor lights to include mood shadows. I'm sure you've seen this on TV but maybe not in 3D. What will be lacking, I believe in the Bloggie 3D will be the geometric accuracy of the image due to the tiny lenses vs the large broadcast glass of the bigger cameras.
post #18 of 124 Old 05-03-2011, 05:03 AM
Frank's Avatar
By vertical disparity I am referring to the misalignment of the cameras in the vertical plane.
It appears that the camera's "pitch" axis are misaligned.
I run into this all the time with twin cameras and my FUJI W1 has it also.
Frank is offline
post #19 of 124 Old 05-03-2011, 07:48 AM - Thread Starter
Don Landis's Avatar
Liked: 326
Thanks. And how did you determine that?
Everything here looks to be aligned when using the tripod. When hand holding the jiggles ( jello as one person called it) sets in and all bets are off for that.
post #20 of 124 Old 05-03-2011, 08:31 AM
Frank's Avatar
I am particularly sensitive to this particular issue having had to deal with it many times over the last year. The left and right views are displaced vertically and it's easy to see. I noticed it instantly even while viewing the YouTube video in checkerboard mode which is what I normally use.
It's even more obvious when using anaglyph.
Frank is offline
post #21 of 124 Old 05-03-2011, 10:36 AM - Thread Starter
Don Landis's Avatar
Liked: 326
OK. I did figure out how to measure it using a screen grab of SBS, both hand held and tripod. I could select a particular speck in the image and measure its position on the left and again on the right. I see that both hand held and tripod has the left image 12 pixels lower than the right.
Then I took a screen capture of one of Joe's scenes and did the same procedure in Photoshop but discovered his JVC was 3 pixels lower on the left than the right. I repeated for different scenes and the measurement was consistent on both the Bloggie and his JVC. Then I looked at your clip I had on my timeline in Vegas of the parallax test and your JVC was zero pixel difference. I only checked one frame grab.
Next I took my frame grab and cut and pasted the left side of the jpg 12 pixels lower so that it had complete vertical alignment, built a 2 minute clip of corrected and uncorrected segments. Played it back in 3D on a 24" monitor and looked at the detail of the scene. While there was a little blip when the corrected switched to un corrected, I could not see any improvement in the sharpness or color between the two. I'm sure that the farther apart the two images are misaligned, the worse it will get and zero difference is perfect.
I think I could write a script to do a correction for all my Bloggie video but would the effort be worth the trouble?
Edit note- Forgot to say that I was viewing in anaglyph mode but I will redo this on my Sony PJ as the difference there may be significant. Must say that I had hoped for a bigger improvement with the zeroing in on the vertical alignment. You must have very sensitive eyes while mine must be very tolerant. I appreciate you bringing this to my attention however, but now I have to decide if it is worth the trouble to correct it. Hopefully the camcorders costing 6 times as much will be better aligned.
post #22 of 124 Old 05-03-2011, 11:04 AM
Frank's Avatar
The error on the Bloggie is not severe enough to worry about IMO.
I just thought I would mention it.
Expecting a cheap camcorder like this to have close to perfect alignment would be unrealistic.
Frank is offline
post #23 of 124 Old 05-04-2011, 03:31 PM
RickD_99's Avatar
Quoted: 113 Post(s)
Liked: 90
Just got my 3D Bloggie this afternoon and so far I am rather impressed. I have been viewing the Sony 3D SBS vids on a Samsung C7000 plasma.
Only disappointment is the non inclusion of a HDMI cable...the HDMI out port on the Bloggie is a non-standard smaller size and I could not find any mention after googling of the proper size HDMI cable. Anybody have a source for the proper size HDMI cable to use with this device?
My <somewhat> 3D YouTube Channel: https://YouTube.com/c/davis.rick393
RickD_99 is offline
post #24 of 124 Old 05-04-2011, 04:06 PM
RickD_99's Avatar
Quoted: 113 Post(s)
Liked: 90
Never mind I found this one: http://www.monoprice.com/products/pr...seq=1&format=2 on Monoprice.
RickD_99 is offline
post #25 of 124 Old 05-04-2011, 04:32 PM - Thread Starter
Don Landis's Avatar
Liked: 326
That's the right one but I ordered one last week and what arrived was not a mini. Now I have to decide whether to return it or just keep it. Cheap enough!
post #26 of 124 Old 05-09-2011, 11:54 PM
TonyW79SFV's Avatar
I've had the MHS-FS3 Bloggie 3D (or 3D Bloggie) for a week and am impressed with the quality in natural sunlight. This pocket cam is a keeper, but I'm still torn with using it vs. my TX7 CyberShot for still as it lacks a real camera flash, instead of that dinky LED. Anyways, here's footage from this past weekend's National Train Day at Los Angeles Union Station of a Santa Fe 3751 steam locomotive departing the station.
post #27 of 124 Old 05-10-2011, 09:32 AM - Thread Starter
Don Landis's Avatar
Liked: 326
Tony- You need to go to your account on You Tube and add the 3D tags so You Tube will display in 3D.
post #28 of 124 Old 05-10-2011, 10:43 AM
RickD_99's Avatar
Quoted: 113 Post(s)
Liked: 90
Just got the cable mentioned in message # 24 above from Monoprice yesterday and lo and behold it was the correct one! One interesting thing to note about using HDMI to view files directly from the Bloggie is that (at least on my Samsung PN50C7000 plasma) the TV automatically recognizes the Bloggie recorded files as 3D when using HDMI. Conversely when I put the SBS files from the Bloggie on a USB thumb drive and play the files via USB then I have to manually set the Samsung to SBS 3D format prior to playback. So bottom line is that it is well worth the $3 investment in the Monoprice HDMI cable if you are interested in fast playback of your Bloggie files directly from the camera with a minimum of hassle!
RickD_99 is offline
post #29 of 124 Old 05-10-2011, 10:55 AM - Thread Starter
Don Landis's Avatar
Liked: 326
I got the right cables now. At that price I got two, one is 12 ft I think. It will reach my couch better. Haven't used them yet as they just arrived.
I am rendering a shortened version of the video I edited in Vegas all shot with the Bloggie except for the picture of the Bloggie in the end which was shot with my cell phone.
The longer version is on blue Ray and looks very nice as the lighting was very bright.
I should be able to upload it later today.
post #30 of 124 Old 05-10-2011, 11:26 AM
RickD_99's Avatar
Quoted: 113 Post(s)
Liked: 90
Cool I will look for it later on...I am going to take my Bloggie to an air show here in North Carolina this weekend and will try to upload some footage next week if possible. Hope the weather cooperates!
RickD_99 is offline
Reply 3D Source Components
