LCD Viewfinder Loupe for JVC GS-TD1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2011, 12:29 AM - Thread Starter
dwhite601's Avatar
I've found a rather useful accessory for the JVC GS-TD1 camcorder. I'm used to using a proper viewfinder, but the JVC GS-TD1 only has a flip out LCD display. It's a nice display, but is washed out in sunlight making it difficult to set exposure levels.
I found this Hoodman accessory for the Sony EX1 that fits the JVC GS-TD1 rather well.
It's available for $153 on Amazon.
I got a chance to use it today at the Los Angeles Renaissance Fair. By mid afternoon, the sun had made seeing the LCD a problem at the fair's outdoor stages. Strapping on the Hoodman solved that problem nicely. The LCD was sharp and I could easily set my exposure levels. The display comes with a focus adjustment solving another problem my 50 year old eyes have. With the LCD alone, I need strong reading glasses.
The display is rubber and fabric so doesn't scratch the LCD surface. It is somewhat heavy so I take care not to overstress the LCD hinge. Of coarse, it's inconvenient to have to remove it to access the menu, but at certain locations, it's utility makes that inconvenience worth it.
dwhite601 is offline
post #2 of 3 Old 05-02-2011, 12:38 AM
NorthTV's Avatar
Nice find and assume it would work equally well on the now being released Sony 3D camcorder as well. Curious which of the two has the stronger hinge attachment as that would obviously be a concern as you note. Also assume one could gerrymander a lighter piece using a coin collector's similarly shaped loupe, and some velcro tape. It would be sans the focusing feature but would provide for a decent sun shield.
NorthTV is offline
post #3 of 3 Old 07-17-2012, 02:19 AM
jwaghorn's Avatar
Hi,
I'm thinking of building an Electronic Viewfinder for the JVC GS-TD1. Lack of a viewfinder has prevented me buying one so far.
Does anybody know if there is video available from any of the GS-TD1's connectors while the camera is in RECORD mode?
I can't find the answer anywhere.
Hoping someone can help!
Best wishes,
jwaghorn.
jwaghorn is offline
Reply 3D Source Components
