The charging process for my 3D glasses is very specific - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-06-2011, 06:54 PM - Thread Starter
GAMESHARQ's Avatar
I bought the Panasonic Starter Kit with 2 pairs of rechargeable glasses and Avatar 3D.
The charging process for the glasses is this:
1. Turn off TV
2. Turn off 3D glasses
3. Connect glasses to TV using the included USB cable to charge
Do I really need to connect them to my TV? Will they charge if I connect them to my PC for example? Also, do I really need to turn of the TV off first?
GAMESHARQ is offline
post #2 of 4 Old 05-06-2011, 07:28 PM
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
Any usb port should work. Even the usb wall chargers.
bigbarney is offline
post #3 of 4 Old 07-04-2011, 06:40 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
You can use any USB port for charging... it could be on a computer or USB hub or a TV or Blu-ray player or even a phone or iPad/iPod charger. When you use USB ports, they don't all operate the same way, especially on laptop computers. Laptops often disable USB ports completely when they are turned off so there's no battery drain. Some desktops may keep the part of the port that charges active even when the computer is turned off. Macintosh computers may charge while in SLEEP mode, but NOT charge when turned off... but there are so many variations on this you HAVE to check how various USB ports operate when the device they are connected to is off, on, in standby, in sleep mode, etc.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #4 of 4 Old 07-11-2012, 09:45 AM
cynsoc2's Avatar
Is there somewhere you can purchase an external charger to charge all four pairs at the same time? thank you!
cynsoc2 is offline
Reply 3D Source Components
