HDMI Booster/Extender and 3D help needed... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-06-2011, 07:33 PM - Thread Starter
ktong's Avatar
Will a cat6 booster/extender in combination with two 15ft or 20ft Certified High Speed HDMI cables support 3D?
If not any suggestions on how to support 3D for a 30-40ft run?
Thanks for your help in advance!
ktong is offline
post #2 of 4 Old 06-06-2011, 10:03 PM
Colm's Avatar
Liked: 94
Two 15', or 20', high speed cables in series do not make a 30', or 40', high speed cable. That said, 3D at 1080p/24 or 720p/60 at standard color depth should be doable with a high quality cable. The bandwidth required is well below the maximum bandwidth of HDMI.
Colm is offline
post #3 of 4 Old 06-17-2011, 12:47 PM
TrickMcKaha's Avatar
I think you can buy 40 or even 50 ft. HDMI cables from Monoprice that will do the job fine, and they won't cost much. I'm using one for 3D myself.
TrickMcKaha is offline
post #4 of 4 Old 06-19-2011, 04:19 AM
BioSehnsucht's Avatar
I just bought the HDMI extender over two cat5e/6 from monoprice (Product ID 8008) and I have tested it over two 75' cat6 I also bought there from my Panasonic BDT100 to my Mitsubishi 3DA-1, as well as from my PC to the TV and it passed both HDMI Full HD 3D (in other words, HDMI 1.4) and 1080p/60 without any problems. I'll be using this to send HDMI from the living room to the bedroom, I'm going to buy another set since it works to send from living room to the kitchen.
BioSehnsucht is offline
Reply 3D Source Components
