BDT110 force 3D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-15-2011, 12:41 PM - Thread Starter
3Daddicted's Avatar
Is there any way to force the BDT110 from Panasonic into 3D mode. I have a DLP projector + converter set-up but it won't enable 3D playback as it can't see the display. Panasonic is beyond useless, they insisted the projector wasn't 3D ready for instance.
I'm hoping someone smarter than I has found a way to circumvent this design flaw. Or is this a lost cause?
3Daddicted is offline
post #2 of 5 Old 06-15-2011, 01:36 PM
JOHNnDENVER's Avatar
It is supposed to see the converter as the 3D device / display.
I am confused. What converter? This should be working for you.
JOHNnDENVER is offline
post #3 of 5 Old 06-15-2011, 02:48 PM - Thread Starter
3Daddicted's Avatar
It's viewsonic converter box. It works as advertised except in regards to the panny blu-ray player. Comcast was, and the PS3 is, converted just fine - they were plug and play. But the panny BD player ....not so much.
post #4 of 5 Old 06-17-2011, 05:48 AM
sdolen's Avatar
Quoted: 48 Post(s)
Just ordered a 110 to use with my 3dxl, I'll report back if I have the same issue. I have had no luck getting my HTPC to play 3DBR so I really hope it works.
sdolen is offline
post #5 of 5 Old 06-17-2011, 06:41 PM
sdolen's Avatar
Quoted: 48 Post(s)
Setup 110 to my 3dxl tonight, aside from turning off Secondary audio to get bitstreaming working, there was nothing else that I had to do. So if it works with the Optoma box, it should work with the Viewsonic one. Try a different HDMI cable? Not sure if it matters but I'm running through a Onkyo TXNR1008.
sdolen is offline
Reply 3D Source Components
