3D setup help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-21-2011, 07:28 PM - Thread Starter
chrisb10a's Avatar
After many hours of searching around for help I'm pretty stuck... any help would be appreciated!
My setup:
Mitsubishi 73833 with 9.03 firmware update
PS3 as the 3D Blu-ray/game source
3DC-1000 kit to convert the PS3 output to checkerboard
Onkyo TX-NR3008 receiver
all 1.4a/3D capable HDMI cables
If I connect the PS3->converter->TV then the 3D works fine but I get no sound.
If I connect the PS3->converter->receiver->TV then the sound works fine but I get no video. The TV reports "TV Not Compatible with 3D Adapter".
I have the TV input set to Game and have FX gaming turned to "on" and "standard".
I have messed with dozens (hundreds?) of receiver/TV/PS3 setting combinations and can't find anything that seems to work. I have restored the PS3 to defaults and I took the receiver out of the box today.
The receiver appears to be working fine for all other non-3D sources. The receiver monitor out setting is "HDMI/main" and "through" though I have tried "auto" and pretty much all of the other possible combination of settings.
Any thoughts or suggestions would be welcome! I can't wait to get this all working...
Thanks in advance,
Chris
chrisb10a is offline
post #2 of 3 Old 06-22-2011, 08:51 AM
JOHNnDENVER's Avatar
Use the optical connection,,,
If the AVR is 3D compatible? You should be able to go source-avr-adapter-tv
JOHNnDENVER is offline
post #3 of 3 Old 06-23-2011, 08:17 AM - Thread Starter
chrisb10a's Avatar
This worked on the first try! Thank you so much for the suggestion!
Reply 3D Source Components
